Question about KitchenAid KSBS25FK Side by Side Refrigerator
Model KSBS25FK side by side--the ice maker not making any ice
  • 4,066 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Oct 11, 2010
My side by side model kscs251nss01 superba will not make ice i have checked the water supply and it is ok need your help thanks i did notice that after i purged the water line it made ice for about 2 hrs
in looking up this model . i belive the ice maker head is at fault . it's very common for the main drive gear to brake its center drive and it some times will deliver but will quit . the complete ice mker is less costley than just the head . . but do ck the freezer tempt as it must be 15 deg or lower . mm
Sep 23, 2010 | KitchenAid KSBS25FK Side by Side...
The ice maker is not functioning?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | KitchenAid KSBS25FK Side by Side...
Icemaker water line is frozen...i will remove everything and open the freezer door to let it warm up. When I chill the freezer again do I keep the icemaker arm up until the freezer is cold and then lower...
Dont leave freezer door open it will cause alot of problems. The ice maker will not call for water until the temp in freezer is cold enough. Remove the ice jam. If you remove from back of freezer it helps alot. Pull out of the back wall and remove ice be sure to put it back the way it was. Any further assistance please feel free to contact me.
Jun 16, 2010 | KitchenAid KSBS25FK Side by Side...
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build up in freezor compartment , on food and in ice bin
the defrost heater may be open (not shorted) Most time the defrost heater lamp has failed. It is behind the panel in the rear of the freezer.
Apr 23, 2009 | KitchenAid KSBS25FK Side by Side...
Or Refrigator Has a bad odor that makes the ice smell bad and taste bad.
put a box of baking soda in frig and in freezer and see if you have something that has gone bad in the frig
Apr 12, 2009 | KitchenAid KSBS25FK Side by Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice shute does not seal
There is a plastic clip that has broken off of the icemaker chute door spring latch on the refrigerator door. This is a common problem and a replacement kit is available from whirlpool to correct this problem. If you contact whirlpool directly they will help you out with a part number for the kit.
Mar 12, 2007 | KitchenAid KSBS25FK Side by Side...
KitchenAid KSBS25FK Side by Side Refrigerator Logo
107 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
