Question about Philips 42PFP5332D 42 in. Plasma Television
TV Question: How To Fix My TV That Turns Off When I Press The Power Button? Sounds like the safety fuse in it is shutting it down and will not power on just clicking noise
  • Philips Master
  • 8,457 Answers
The tv power supply board have problems,not giving the tv the right voltage anymore.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Posted on Oct 11, 2010
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Old bell expressvu remote and i cant syncronize it with tv. Remote works fine with receiver but i dont know how to rpograme it to shut off tv.
Hello!! There are a few ways to get this working to shut off the TV. I put some instructions at the bottom here. These are instructions for a power scan, which scans the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Mar 01, 2011 | DISH Network IR Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Power off presents magic focus screen, tv must be unplugged.
you will have to determine if tv fault or cable fault, shut down cable box and unplug it`s power cable. Once all power is removed from cable co. equipment retry your tv controls, if tv turns on correctly problem with cable co, if not tv has corrupted data (try unplugging tv for 1 minute and then retry) ifstill bad tv has bad control board or logic problem, either one will require tv tech to fix, hope this helps, video-tek
Jun 01, 2009 | Hitachi 57F500 57" Rear Projection...
Press Pwer Tv sounds like its starting turns off then back on
CK capacitors cp114,120,150f any of them are puffed up on top then replace all 3 capacitors 2200uf 16v and two 220uf 35v. resolder all pins on FBT flyback transfomer.
Feb 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi WS-55807 television
this tvhas a built in safety feature, fuse, sometimes you can hear a faint popping noise when you turn the tv on and it shuts down. This feature was designed to prevent power surges from hurting your tv any more than it already is. You will have to have someone repair the small problem you have now and reset the tv. 10% of the time you can try holding doen the menu button for 10 seconds and/or unlpugging it for 4 hours to do a hard reset. This hardly ever works though. It will probably cost you about 200 to 500 to fix it. sorry
tom
Jun 05, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
Strawberru shortcake tv turns on then right back off
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Jan 15, 2008 | Spectra (SS213) 13 in. Portable Television
Philips 42PFP5332D 42 in. Plasma Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
