Question about Dishwashers
My dishwasher Midea WQP12-9240A is stuck on the rinse light, flashing and beeping.. It wont reset and is not rinsing. Please help me to reset it.
SOURCE: Midea dishwasher WQP12-924OA wont go
hold power button down for 10secs while plugging in mains
Posted on May 07, 2008
I had the exact same problem with the exact same model. It sounds unlikely, but I couldn't get it to work until I clipped the drain hose into one of the clips 2/3rds of the way up the back.
There was a sticker there that said "the drain hose must be attached to the left or the right clip"
Posted on Jul 30, 2008
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
Posted on Feb 16, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Dishwasher does not wash simply beeps continously and wont start the rinse cycle with green flashing pre rinse light. Have tried turning off at power and have checked all connecting pipes. Have emptied...
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
Apr 06, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
I have a a whirlpool dishwasher ADG7440
hold down the on button for 5secs it will reset
Jun 24, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Kenmore dishwasher 16764 Quick Rinse Light won't go off
you can try reseating the ribbon cable on the board however i strongly believe you have a stuck key and the key panel will need to be replaced.
Feb 02, 2009 | Kenmore 16764 Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
Owen Barnes
