Question about Kenmore 75922 Gas Dryer
The dryer drum keeps turning when i open door. light does not turn on either
  • Kenmore Master
  • 43,501 Answers
That is kind of the opposite of these tips.... the door switch is stuck on the in (or closed) position
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 11, 2010
4 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Posted on Aug 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: When door is opened Dryer Drum keep turning. Will
Posted on Jul 22, 2010
SOURCE: The dryer won't turn on
I have the same dryer and the same problem...I have power to the unit but it wont turn on....the light in the door is on....there is a small cllick to the top left when I try and start it..thats it..!!...did you get a solution yet?..thanks..mike
Posted on Jun 23, 2011
My dryer will not turn off! The drum keeps turning even when I open the door! Help!
You need a new door switch.
Google
Make Model door Switch.
Presumably you can turn it off with the timer. If not, you need one of those too.
Nov 26, 2015 | Dryers
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
Kenmore 75922 Gas Dryer Logo
161 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
