Question about GE GTS22KBP Top Freezer Refrigerator
How do you get to the evaporator coil? - GE GTS22KBP Top Freezer Refrigerator
    President:
  • 1,891 Answers
Remove the back of the freezer / if unit has ice mker . remove it first . coil is behind the back plate about 4 screws. / be carefull of the wires connected . ..mm
Posted on Oct 11, 2010
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Does the evaporator coil HAVE to be removed to clean it or can I just spray it? It seems to be in adifferent location than the ones I see online. Mine is on the bottom and visible when I open intake
The evaporator cannot be removed. To do so you would have to drain the freon. You can just spray it with a cleaner in any manner that you want.
Nov 25, 2013 | Heating & Cooling
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
Kmonogram built in refrigerator, where is the evaporator coil and how to vacuum it.
Finding the evaporator will take disassembly of parts of the cover on the top of refrigerator. If you have other questions please let me know. Just be really careful to not damage the evaporator and unplug before working on your Monogram you need to find the evaporator coil to repair, replace parts or work in that area it is on top of the ZISS480NRSS and listed as part location #800 in the photo below. Click below to enlarge,
ZISS480NRSS Parts ZISS480NRSS Service Manual
Thanks, Sea Breeze
Aug 06, 2012 | GE Monogram ZISS480NRSS 48" Built-In...
How do I access the evaporator coil for my AC unit
Hello, usually it is not a easy task. You must cut into the plenum where the evaporator coil is located and then cover the hole back up with sheet metal. Also, be very carfull when you cut into the plenum so you dont puncture the evaporator coil.
Aug 06, 2011 | Goodman Heating & Cooling
Looking for evaporator Coil number for Carrier Model 24ANA736
Are you replacing or adding an evaporator coil to this system? If replacing, please give us the model # (and product #) of the evaporator coil. If you can't find one for it, we will need the air handler (or gas furnace) model # so we can help you match it up.
If you just want the condenser coil for that condenser, the part # is 331230-7035.
Mar 24, 2010 | Carrier Heating & Cooling
Why does my kenmore cool on he bottom on both
replace evaporator fan motor.it is the fan above the evaporator coil's.
Nov 18, 2009 | Dishwashers
Hot compressor
If you have a fan near the compressor make sure it's running. Make sure the evaporator coils on the back or under the unit are clean. If the evaporator coils are ice up it can also cause this problem. The evaporator coil is behind the rear cover in the freezer.
Oct 28, 2009 | Magic Chef MCBR440 Compact Refrigerator
Unit freezes up when nearing 8-12 degree superheat
check to see if your evaporator coil needs cleaning
Apr 29, 2009 | Goodman CLJ30AR32 Air Conditioner
GE GTS22KBP Top Freezer Refrigerator Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
