Question about Kodak Ektapro 9020 Slide Projector
When I turn the projector on the red LED lights both stay lit. Have tested globes and also changed same. Still red LEDs stay lit. Have checked fuses. All OK
    President:
  • Kodak Master
  • 412 Answers
Based on your description, what usually causes the condition you are seeing is a loose terminal in one or more of the lamp sockets or the mating terminal assemblies (the one on the lamp module & the one in the projector itself). In one of these contacts you have a bad connection.
Posted on Nov 09, 2010
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
My Optima Projector flashes the red light on the Lamp & temperature L.E.D's at the same time. Power gets to it but after the LEDS flashing for some time, it automatically turns off then on again and...
Sounds like your bulb has gone.
Unplug it.
Clean all the filter.
Remove lamp and inspect it, check for darkness, cracks and if filament has blown.
If lamp looks ok, put back in and test.
Dont touch the lamp front glass with your fingers as this can damage lamp.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Optoma EP721 Projector
Infocus lamp replaced - still does not work. LED lights on control panel not on either.
without knowing the model of projector, i would say that you need to replace the power supply. the leds are lit from the initial 5v when the power supply is on. no leds, bad ps.
Jan 02, 2010 | InFocus Office Equipment & Supplies
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
Projector wont switch on.
if there are no leds lit on the top, then the power supply is bad (check the fuse on it first). if there are leds lit, which ones, what color, and are they flashing, and how many times? this will tell you the problem.
Sep 11, 2009 | Sony VPL CX5 Multimedia Projector
Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Jul 15, 2009 | Office Equipment & Supplies
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Kodak Ektapro 9020 Slide Projector Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
