Question about Maytag MDE9700AYM Electric Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
  • Maytag Master
  • 2,963 Answers
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Posted on Mar 01, 2015
  • Maytag Master
  • 43,501 Answers
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 11, 2010
When the start button is pushed there is a loud buzzing sound like the cycle has ended. after turning the timer to start another cycle the start button continues to buss.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Apr 17, 2011 | Amana NGD5200TQ Dryer
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Maytag MDE9700AYM Electric Dryer Logo
175 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
