Question about NetGear WGR614 Wireless Router
Network I am running a laptop with XP Home downstairs which is permently connected to a netgear wireless router as my father is disabled he doesnt move around. Now upstairs i have a desk top with Vista Ultamate 64 running from a Homeplug one home plug running through the wireless router and the other connected to desktop upstairs. We have a 10Mb service from our ISP, but when i do a speedtest on the laptop ( i get a 9870 which i figure is about right but when i do the same thing upstairs the best i manage ranges from 2785 to 6785 tops. The latter is most common. The homeplugs are the 85 Mb type. Is it because of the wireless router. Should i just buy a single adsl modem to replace the one from ISP but has more eithernet connections on the back...Anyhelp on this would be great as im fed up with all the money i have probably been wasting :(
  • 68 Answers
Hi wild11967
re homplugs let me infor you first that Homeplugs do have a minor advantage if they share the same leg but there is usually sufficient cross-coupling.Larger commercial buildings often have 3 phase where each phase has its own transformer. Homeplugs need to be on the same transformer.
Also Long extension leads will degrade the signal so it is best practice to plug the HomePlug directly into a wall socket As with the figures youve given above you dont NEED to purchase a new equipment such as a router as youd have the same issue with it.
Best thing to to check your circuitry as - limitations are as follows - the rings or circuits (such as upstairs and downstairs) mains must be on the same fuse box / consumer box.
If you have further questions let Fixya answer it for you .
Best wishes .
Posted on Jun 11, 2008
I have a netgear wndr3400 wifi route in use. It is located in my office at home. It is upstairs in the front of the house. My laptop is downstairs in the rear of the house. The system works but does drop...
WNDR3400 is a dual band WiFi router.
In case your Laptop has Wireless N card then you can can use Wireless N on WiFi else you need to use Wireless G.To enhance the Router performance Disable one WiFi Network on your Router(Either N or G) and configure Channel 11 for long range signals.
To configure said changed you need to login into Router ( or IP address to find your router's IP address (Gateway address is the router address)Type User name and passwordDefault username and password for netgear routersUsername : admin Password : password
Goto wireless settings and disable one of the wireless network a per your requirements (N 0r G, if you have Wireless G adapter on your laptop then suggest you not to use Wireless N)Changed Channel - 11
Save settingsAnd reboot Router
Hope this helps
Jul 12, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
I have a netgear router which i use for laptop and home pc, laptop is working but pc is not how do i reconfigure with code to enable home pc to work?
If u r able to go online wirelessly then the router wireless connection is configured and to connect your pc wirelessly just need to scan and connect to the network. To scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.You ll be able to go online wirelessly if you still have problem let me know ll help u.Thank you
Oct 29, 2009 | NetGear DG834G Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Netgear wireless router
Try these:
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
95 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
