Question about Fisher and Paykel Washing Machines
Turned on machine MW059AU top loader and will not fill with water. Any ideas?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.1st turn off the taps to the machine and remove the 2 inlet hoses at the machine end.Now put these ends of the hoses into a bucket and turn the taps on a little bit to see if you are getting any water out of them.Make sure you note where the hot and cold hoses go back.Check the little filters where the hoses connected to the machine to see if they are blocked.If you have water coming out of the hoses and the filters are clear then refit your hoses to the machine and turn the taps on.Now try a hot fill then a cold fill.Now reply back and tell me how it went.Then I can help you rectify this fault on your machine.Looking forward to your reply.
Posted on Oct 11, 2010
My F&P model MW059AU top loader washer suddenly lost power and stopped half way through wash. Power point ok. Is this repairable?
possibly but you will not know until you get in a technician to do a proper diagnosis of the problem
Apr 24, 2017 | Washing Machines
Asko front loader fills with water when switched off and once turned on will immediately sense it and drain it from the machine. What could be the problem? The machine still washes beautifully, even after...
inlet valves are out of service or malfunctionnign follow the steps .
1. unplug your machine power cord.
2. open the door and also open water supply , if your machine fills the water then 100 % problem is with your inlet valves , replace it , simple
regards
Dec 31, 2014 | Asko W6021 Front Load Washer
Barel is not turning
Hay Ivan , if its a top loader then replace motor coupler if its a front loader replace the belt .good luck ALLIANCES R EN
Mar 01, 2013 | Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
Water does not switch off automatically when full. It overflows. The machine will not run when the water is turned off at the tap.
If this a front loader machine, the water entry is a timed event. If a top loader, there is a water level switch located on the top of a tube which comes up from the bottom of the outer tub and is near the machine top. The switch is really a pressure switch, which requires no air leakage from the tube or switch to function (the rising water level in the tube generates the needed pressure). Open the machine top to watch what occurs when filling and manually check the operation of the switch.
Oct 24, 2009 | Washing Machines
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Top Loader Washing Machine - Model 3RLSQ8033RW2
it may be a bad water valve or just a clogged screen. take off the cold water connection from the back of the washer and clean out the screen you see inside the plastic piece the hose fits on. do not take it out, clean it while it is still inside.
Aug 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
121 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
