Question about Hitachi 65SWX20B 65" Rear Projection Television
The blue droops down in the middle at the top and bottom corners. And in the manual allignment it wont let you line the blue up in them areas. What do I have to do to fix these problems?
  • Hitachi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
The blue droops down in the middle at the top and - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green and red a little blue everything is doubledup lines droop down from the top everything is dropping to the middle
CONVERGENCE PROBLEMS. WILL REQUIRE PARTS REPLACEMENT. POSSIBLE VERTICAL DEFLECTION FAILURE ALSO
Dec 27, 2009 | Zenith R57W46 57" Rear Projection...
I dont know how to allign my i mate pda 2k. how? pls help me.
Go to the "phone programs" screen page and at the bottom left,select the touch screen allignment option.select and follow the instructions.You will have to continue tapping the cursor till it stops moving.Then your screen will be alligned.
Jul 03, 2009 | i-mate PDA2k Pocket PC
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
LINE ACROSS TOP OF SCREEN-LOOKS LIKE A GASKET
I have the same problem with the gasket dropping from the top of the screen. I took the back casing off (approximately 16 screws) don't forget to take off the adaptor box with two screws. and the additional 8 screws located at the bottom of the panel casing. After that the back panel will come off. Remove the tv screen from the front casing, approximately eight screws. Be careful not to dislodge any wires while remove the screen. Finally remove the gasket. All of this can be done at any local tv repair shop for about $150 dollars.
Dec 02, 2007 | Protron PLTV-32 Television
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
Hitachi 65SWX20B 65" Rear Projection Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
