Question about Brother MFC 240C All-In-One InkJet Printer
My scaner says to check connection, but I'm not sure which connection?
    Sergeant:
  • 270 Answers
Most scanners connect to the computer using a USB cable. The computer must recognize the device on the other end. So too mus the scanner see the computer.
Unplug the USB cable from the computer and wait about 5 sec. Plug it back in and you should hear a connection sound, and the software will have a pop up that shows connected.
good luck and don't forget to vote!!!
Posted on Oct 11, 2010
Error E221 shown
A E221 deals with the scaner unit. I believe you are working on a Canon copier? I'm not sure what model? Odds are the scanning lamp is not working correctly.. I would check the lamp & fuse to see if they are blown or it could also be the power cable for the scaner lamp..... Good Luck
May 28, 2012 | Office Equipment & Supplies
WE HAVE A FAX MACHINE THAT HAS A BLACK LINE GOING DOWN THE PAGE WITH FAX IN AND FAX OUT
For outgoing fax lines, check your scaner rail for any streaks, dirts or similar and clean scaner.
For incoming fax streaks, you can only check your drum unit for lines on surface and replace it, or lines is there because other side has dirt or similar on their scaner.
Hope that helps!
Aug 09, 2010 | Office Equipment & Supplies
How to scan photos to the computer
start - program- lixmark scaner- click on it-the diloge window for scaner apper choice the dip as300 or more put 300 is good then choice the jpg for hoto to be very easy when you have save the photo make prevew for the picture the scaner will make scanning for the picture in the glass then will apper on you moniter computer select the part you want scanning by mouse then click scan when finish save it .make sure you instull the scaner in your computer good.
Dec 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
How do i connect my epson scanner 3490 t0 my epson r220 printer
i am not sure if the two could be readily connect. but, you may connect them on two of the USB port on your PC at the same time.
Oct 07, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scan document to computer
install driver of ur scaner
now connect it with ur comptuer
install photoshop
open photoshop go to file click in import and select import via ur scaner name and it will scan document
Oct 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I need to install a printer,scaner,copier
You can download most of them from the printer company for free. Sounds like HP.com for you! Warning, when you install, make sure the printer is not connected to the computer until the installation program tells you to connect it. Have it plugged in and turned on and have the usb cable attached to printer.
Jun 06, 2009 | Office Equipment & Supplies
The scaner plugin in my ford f150 doesnt work
Check the fuse for the cigarette lighter, most car makers use the same circuit for power to the OBDII connector.
Mar 10, 2009 | 2000 Ford F150 Flareside SuperCab
Hp1610 scaner/printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP PSC 1610 All-In-One InkJet Printer
Scanslim c6 problem with vista
At this time the drivers for the C6 ar not compatable with Vista. Check this site http://www.microtekusa.com/ for updates and be sure get all your updates for Vista.
Jun 09, 2007 | Microtek Slimscan C6
Brother MFC 240C All-In-One InkJet Printer Logo
565 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
