CPF connectors how do I know which end of the plug is +ve or -ve?? does the colouring of the wire give a clue?? one is white and one is green. e.g. for the PWR_LED plug
  • mightyreal May 31, 2008
    ok that might have been the problem... I'm gonna try plug this baby in now... thanks so much man
    there is life!!! lights and everything! but nothing on screen! the light on the monitor is flashing.... seen it like that before actually... but don't know how to sort it... is it to do with static??
    Scholar:
  • 187 Answers
It should usually say on both the cable, and the board. If not, white is usually +
Posted on May 31, 2008
  • Steven Burn
    Steven Burn May 31, 2008
    If there's nothing on the screen, check the connection to the graphics card, and if it's not an onboard graphics card, try either a different one, or try reseating the card.
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
Need to know speaker wire colour config for 1994 4runner (toyota) as well as power and earth wires
A Right Front Speaker (+) Green Gray B Left Front Speaker (+) Pink White C +12 Volt Ignition Wire Gray Red A B C D K L D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow E Right Front Speaker (-) Blue Gray w/ Black Stripe E F G H I J M N O P F Left Front Speaker (-) Purple White w/ Black Stripe G Ground Wire Black Black H Power Antenna Wire 1 Blue (join wires 1 & 2 I Power Antenna Wire 2 together to this blue wire) AS VIEWED FROM MATING END OF CONNECTOR Do Not Use J K Right Rear Speaker (+) Red Purple L Left Rear Speaker (+) Black Green M Right Rear Speaker (-) White Purple w/ Black Stripe Do Not Use N Do Not Use O P Left Rear Speaker (-) Yellow Green w/ Black Stripe
May 29, 2010 | 1994 Toyota 4Runner
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
15''lcd monitor cable problem.
Hi, this may not be solution for what you ask but rong signal can or mayset u monitor on flames it hapined to me, why? hold on to old cable whan you can go and get new one, if you say you cant find, then get a moltetester chack the each ends pin to pin for contanuity. good luck
Jun 22, 2009 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
100 Ft. Cat 5e Cable damaged
I suggest soldering them, it is real easy and I could walk you through how but it would still work if you twist the together and elecrtical tape them off. Also were at on the cat 5 is it exsposed? If it is near the end you could just put a new plug on it.
Mar 18, 2009 | Cat5e 100 Ft. Cat 5e (100FTCAT53)
4pin blue modular plug under dash for brake controller to plug in
You should be able to access the Prodigy Instructions ie Wiring Diagram At google. Maybe an install video on You Tube. Make sure everything you do is properly fused. Any thing as far as color codes will need to be Prodigy specific. Prodigy may have a 1-800 Tech line. They should be able to E-mail you a PDF file.
Feb 28, 2017 | 1999 Dodge Ram
Wiring mishap with kenwood cd player
For wiring your Kenwood KDC-MP4028, please refer to the below wiring/color guide:
Red - Ignition/Accessory B+12VDC
Black - chassis/GND
Blue/White - external amplifier
Blue - motorized antenna
Brown - mobile phone mute sensor
White - Front Left +
White/Black - Front Left -
Gray - Front Right +
Gray/Black - Front Right -
Green - Rear Left +
Green/Black - Rear Left -
Purple - Rear Right +
Purple/Black - Rear Right -
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Kenwood KDC-MP4028 CD Player
Computers & Internet Logo
424 people viewed this question
David Payne
David Payne
