Question about Texas Instruments TI-30XA Calculator
When I turn it on, a 7 appears on the screen under DEG. Most of the keys don't work, and when they do we often get an error message. I just replaced the batteries, but that did not help. Any ideas? Thank you!
    Sergeant:
    Champion:
  • 387 Answers
Try hard reset
Posted on Oct 12, 2010
I am unable to turn off screen overlay. I tried doing so in app settings by turning off all permission. It is still on, how do I remove it. ZTE 798BLi
Hope this help.
1. From your home page go to Main Settings by pulling down the Notification Bar and clicking on the Settings icon at the top right of the screen. (it's gear shaped)
2. Scroll down the Settings menu, and click on Applications under the Phone section about two thirds down the page.
3. At the top of this new menu click on "Applications Manager".
4. In the top right corner of the Applications Manager menu click on "More"
5. Now a click on "Draw over Other Applications"
6. Scroll down this menu and find the offending application, in this example "Facebook"
7. Click on the button to the right of your offending application to deselect it.
8. Close out of the Settings menus.
NOTE: Alternately, deselect all the applications under step 8 except those you know pop up over other applications such as messaging, for example.
Feb 04, 2018 | ZTE Cell Phones
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
I have DEG on the calculator screen and get figure out how to turn it off??
Press the DRG key to cycle through the three angle modes. Be aware that whatever mode you select, the corresponding indicator will appear on the screen.
The angle mode should not affect the exponential and logarithmic functions. If you still get errors, please post an example or two, including the exact keystroke sequences.
Dec 11, 2013 | Texas Instruments TI 30XIIS Scientific...
The message "Windows 7 Build 7601 This copy of windows is not genuine" has appeared on my laptops screen.
Did it come with Windows 7? Has anyone upgraded the OS? Can you run Windows Updates?
Mar 26, 2013 | Acer Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
How do i calculate cos 30°24'
You must first set angle unit to degree.
Press the [MODE] key a certain number of times until you get to a screen that displays Deg Rad Grad. Press number key 1 to select degree.
Once this is done you can calculate trigonometric functions. To enter angles in DMS you have a key marked with degree symbol, a quotation mark, and a double quotation mark. In what follows that key is represented as DMS.
To calculate cos(30 deg 24')
[COS] 30 [DMS] 24[DMS] [=]
If you get an error message you will have to enter the seconds even if the value is 0
[COS] 30 [DMS] 24[DMS] 0 [DMS] [=]
Sep 11, 2010 | Casio FX-300MS Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-30XA Calculator Logo
85 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
