Question about Maytag Neptune FAV6800AW Top Load Washer
The fabric softener dispenser on my FAV6800AWQ is not flushing. After a wash cycle, there is still a quarter inch or deeper fluid (water & softener) level. I disassemble and clean the dispenser often but it still doesn't seem to be flushing properly. I can't see any solenoid or tubing assembly near the dispenser (except for the lid lock assy) so I assume the flushing pressure originates via the tub wall. I have been unable to locate an IPB (Illustrated Parts Breakdown) manual to confirm. Thoughts, please? Thank you in advance. Ron Scott Friendswood, Texas
  • 526 Answers
Ron,
From what you describe I feel the next check is to make sure the Fabric Dispenser water solenoid is opening all the way to allow enough water to flow thru the lid channel to fill the reservoir. I say this because you troubleshooting indicates a partially diluted softener in the dispenser reservoir.
You can't get the Service Manual from Servicematers.com anymore so I will point you to a previous post on opening the softener water valve in service mode and let's see if the dispenser valve will fill the reservoir. I don't think that will happen from what you describe......maybe after several minutes in service mode.
You will need to turn on the cold water inlet valve in service mode then turn on the Fabric Dispenser water Valve in Service mode and see after several seconds that the Fabric Dispenser fills and the contents are flushed out to the wash tub.
See this post for your issue http://www.fixya.com/support/t4514661-fabric_softener_dispensor_not_empty
If you want to continue to troubleshoot and DIY the fix I would go to another DIY site that will make it a bit easier to support the fix for your issue. Just Google dh1200s and you should find me on a few other DIY forums...........Rich
Posted on Oct 13, 2010
  • Ron Scott Oct 26, 2010
    Hi, Rich. You are correct. The solenoid valve for the softener dispenser is not opening even though 120VAC is being supplied by the control board to that solenoid. (I used the diagnostic sequence you described in the link you provided to verify ( http://www.fixya.com/support/t4514661-fa... ). I have to buy a putty knife to be able to release the front right and left latches for the washer top to hinge backwards for access to the solenoid valve assembly for removal and replacement. I really appreciate your help. BTW, I FINALLY found a currently available PDF file for the FAV6800A service manual which I was able to download ("save target as") to my computer desktop for more help. You must register with an email addy to access the site and get the manual. Here is the link: http://appliancedigest.com/index.php?/fi... Thank you again and
    Best Regards,
    Ron
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Oct 27, 2010
    Hey Ron good deal, yea I joined that forum last week when I found out servicematters.com had put a coin slot on their site. They shoild hang there heads low for lack of support to Maytag owners. I have pointed folks to the site. I'm done with this site. Good luck to you. appliancepartspros.com/ is the site i would recommend for support of the 4 real DIY sites I post on. See Ya FIXYA.
Where do you put fabric softner
Manually: If you're adding fabric conditioner by hand, be sure not to add it during the wash cycle. The washcycle will clean away much of the softener, so add it during the rinse cycle. Also, try to avoid direct contact with fabrics to avoid stains; instead, pour Downy into the deeper pockets of water.
How to Use Fabric Softener Without Dispenser ' Downy
where do you put fabric softener in the washing machine Google Search
Oct 30, 2017 | Washing Machines
Fabric softener holds water
The softener dispenser gets flushed at the end of the wash cycle to prevent clogging.
Aug 28, 2017 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Jan 16, 2016 | Washing Machines
I have water in the fabric softener spot and it won't drain out
Water flushes the dispenser during the wash cycle to remove residue. Some water remains after flushing. It's not a problem.
Jan 19, 2015 | Washing Machines
Why doesnt the fabric conditioner dispenser empty after each wash?
The softener dispenser is flushed with water as part of the wash cycle. The residual water prevents softener from clogging the dispenser between was cycles.
Aug 01, 2014 | Hotpoint Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
296 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
