Question about Maytag Neptune MDG5500AW Gas Dryer
How to light gas dryer maytag neptune - Maytag Neptune MDG5500AW Gas Dryer
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
  • 4 Answers
SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Posted on Jan 10, 2008
  • 1028 Answers
SOURCE: Maytag Neptune MDG9700AWW gas dryer. Problems
be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Posted on Jun 06, 2008
SOURCE: No hot air for dryer
I would check the air duct discharge real good before taking anything apart! A clog down line will cause the igniter to kick off resulting in blowing cold air! You need to sqeeze the air duct or take it off as lynt is soo light you will not even notice a clog but your dryer will! Good luck!
Posted on Mar 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Can the Maytag Neptune Gas dryer converted to electric?
A gas dryer is dedicated to the use of gas to supply its heating function. It works on 125 volts. No way can a gas dryer become an electric one. UNLESS!
you just want to hang out yer clothes under the sun and use the dryer as a way to fluuf up yer clothes OR you could place the dryer into a box and make a condenser dryer out of it. Like cool hand luke you will toss that dryer into a rigid metal box in direct sunlight so that it can be an unbearable 140 degree up in there. then grab yer clothes and toss em in there and close that tar paer lined tin box up my friend.Let the sun do its thang. I think i just invent the redneck dryer! we don't need no stinking gas. Green power to the people! LOL
Posted on Apr 08, 2009
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
I just purchased a Maytag Neptune gas dryer, do I need to light a pilot if not what do I need to do to get it hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[[]
Aug 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How to turn on pilot light maytag neptune dryer
Thing is the dryer does not have a"pilot" it has an electric ignition system with and electric igniter. Go here for more: Dryer Repair Help
Go to RepairClinic.com and enter your model number into the Search box at the top of our website to see all the parts available for the unit.
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Where to light the gas????
you dont light it manually it has an igniter operated by electricity off the control board
Sep 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
May 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
106 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
