Question about Canon Pixma MP480 All-In-One InkJet Printer
I have installed refilled cartridges but it still says "ink is running low", how do I make the printer accept that the cartridges are full?
    Scholar:
  • 39 Answers
That will happen with all refill cartridges on many Canon printers (I own 3) I have attempted several types of refills on the MP620, MP480, and the MP610 and none have worked yet, I went to my local cartridge world and their tech there confirmed it. I believe they're trying to get a solution to reset the chip on the cartridge but as far as I know nothing is available yet.
Good luck
Posted on Oct 11, 2010
Hold down the start/stop button for approximately 3 seconds.
Posted on Jul 29, 2012
5 Suggested Answers
  • 670 Answers
SOURCE: just installed refilled color and black ink
I found these instruction at out-of-warranty.com They seem like a possible solution.
Steps:
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
I hope this is helpful. Good luck.
Posted on Sep 05, 2009
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Amazing solution:
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Brother ink empty cyan yellow magenta..
Posted on Aug 13, 2008
  • 3600 Answers
SOURCE: Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
Posted on Mar 11, 2010
  • 232 Answers
SOURCE: printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Posted on Apr 15, 2010
Have installed new ink cartridge. still getting low inw warning
The low ink cartridge warning is nothing to worry about. If it prints, it prints. Most modern printer cartridges have a chip on it which lets the printer know when the ink is low. When you run low on ink, it sends a message to the printer which sends a message to the computer telling you to refill the ink. The problem is that it doesn't go away once you refill the ink. It still prints, you just get a notification whenever you want to print. You can still use it up until that new cartridge runs out of ink. :)
Feb 21, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Mar 11, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
I have just changed all the ink's in an Epson d120
If you replaced with "genuine" ink-cartridges, then it should report "full".
If you replaced with "refilled" ink-cartridges, then the company that refilled forgot to "reset" the electronics inside the ink-cartridge, in order to report "full".
Or, perhaps, the software "toolbox" that came with the printer has a button "I have installed new cartridges, please re-verify the ink-levels" ??? Click that button.
Nov 27, 2009 | Epson Stylus D120 Network Edition ultra...
Refill cartridges - need to reset ink level monitors
I must tell you that Dell uses sensors in the ink cartridges and the printer. So one the ink cartridges is low on ink, sensor on ink cartridges will show as low and if you get it refilled, there is no way to reset the sensor to full since Dell does not want customers to use Refilled ink cartridges. However if you are looking for Low cost ink cartridges they I would suggest you to purchase Standard Capacity ink cartridges from www.dell.com/supplies. they are almost half the price for hi capacity ink cartridges.
Nov 06, 2008 | Dell 922 All-In-One InkJet Printer
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Aug 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
682 people viewed this question
old marine
old marine
