The Magnavox remote control has stopped turning the set on and off. It works perfectly otherwise - new good batteries have been inserted and it has been cleaned - also the sensor on the front of the TV has been cleaned. Is there a fuse that needs changing? How does one do that? Do I need to order a new remote? The set can be turned on and off manually just fine. Thanks -
  • 8,457 Answers
The remote is dead,the CPU have shorted problems.Try website like Remotes.com to buy an a axact or very close to the original remote.
Posted on Oct 11, 2010
My tv remote magnavox remote control 46mf440b/f7 stopped working new batteries still not working
So now either the remote is fubar or the tv remote section is. Bet it is the remote. Test remote by tuning radio to am band around 600 and turn up volume. Put remote next to radio and press button, any button. Should hear beeping. if nada remote is fubar for sure.
Sep 01, 2017 | Magnavox Televison & Video
Remote not working
Check the remote control for its infrared emission. Check it with fresh batteries.Check and clean the battery contacts inside the battery compartment, for any rust or dust accumulated, which prevents proper battery connection to its terminals.Clean it well, before inserting batteries.If you are using a universal remote control, you have to set it up with the set-up code to your TV brand, otherwise it won't work properly. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view.It will make search easy.
Jan 02, 2014 | Televison & Video
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.
God bless you
Nov 07, 2013 | Tivo DirectTV Remote Remote Control
Remote code for vuz8 remote magnavox blu ray mbp5220f
replace the batteries by new ones
2) clean the contacts batteries with c. cleaner
3) retight the springs contacts batteries, with pliers for a GOOD contacs very importan.
4) open the remote c for clean the KEYpads from corrosion, dirty, dust, oxide, and try again with c. cleaner.
5) reset the code download from www. remotecodelist.com
6) if doesnot work go to the repair shop TV for fix it.
God bless you
Sep 09, 2012 | Vizio VUR8 Remote Control
Turn it on,then it turns off by itself.with the remote or button
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Dec 24, 2009 | Philips Magnavox TP3285C 32" TV
My sony rmez4 stopped working. I have no manual.
If the tv is a magnavox, you should have a magnavox remote or a universal to work it, unless I am not understanding your question. Dale
Jul 07, 2009 | Sony RMEZ4 Remote Control
I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Greetings
CRENDON
Dec 15, 2008 | Philips Magnavox DVD Player MWD200F
Universal remote
Try www.remotecodelist.com Hope that helps.....T.
Or provide Make / Model of combo off back of unit.........Thanks.
Jan 02, 2008 | RCA Universal Remote Control
Need a replacement remote control
Just call Magnavox and get it for $17.95 shipping and all. They are cheaper than any I found on line.
Nov 06, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Grundig Super Colour TV Serie F 3016 - lack of responce from remote control.
Tell me if there is a battery within this TV set which will require replacement to solve this problem
no there is no battary in tv.
The set works OK otherwise using its own control panel to change channels and its on/off switch to turn it on and off.
your statements itself says that there is no problem in tv.
in my opinion problem is in  remote only.
please try
www.remotes.com
for further help in remote.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
