Question about Samsung LN-T2342H 23 in. LCD HDTV
How do i use it a a PC monitor? i am connecting it and receiving a "not supported mode" display
  • 597 Answers
To hook up your television to your PC, first you need to get the appropriate cable which is the cable you use in connecting your CPU to your monitor, then turn the back of the television and try to connect it to the port that is on the television.
Then turn on the television, and go to the AV mode, select from the different AV channels you have to be able to access the laptop.
That is how to hook up your television to your PC.
Take care
Posted on Oct 11, 2010
Mode not supported. That's what I see when I connect to my pc. (WIN XP) Can't get it to work. Ideas?
Your PC video resolution is set too high for the monitor to display, you need to lower to the highest the monitor can support and for the best picture.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Jul 09, 2010 | Mag Innovision InnoVision XJ 717 Monitor
How to make mirror image of second monitor we cannot make the mirror image in our pc which is also connected with first monitor by rgb connector
Select CLONE, Y not spanned desktop. Clone and Span modes tell Windows that only one monitor is present on the machine. They don't give Windows control over individual monitors, but they don't require Windows to support multiple monitors either.
True Multi-monitor mode is different. Here, the display driver tells Windows the actual number of monitors attached to the computer. Each monitor can have its own display and each can have its own independent display resolution and color depth.
Does your computer have True Multi-monitor support? One way to tell is to right-click the Windows desktop and choose Properties from the popup menu then click the Settings tab of the Display Properties dialog box.
You MUST have latest drivers from manufacturers web site installed to. Us the control panel from that to adjust.
Mar 01, 2010 | Microsoft Windows XP Professional
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Apr 28, 2009 | Acer V193w LCD Monitor
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Problem with lcd 22'' tv come monitor connection
firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Nov 25, 2008 | Samsung Computers & Internet
NO SIGNAL What do I do?
These messages are normal when the computer truly goes into suspend mode or loses the video signal (such as when the computer is suddenly turned off).
If the monitor displays any of these messages when the computer should be displaying video , do the following items until an image from the computer appears:
1.
Ensure the computer is really sending a video signal. To bring the computer out of suspend mode: move the mouse, press the spacebar, and press the suspend button on the keyboard twice (the suspend button has an icon that looks like a quarter moon).
2.
Ensure the video cable is connected (and connected to the correct video port).
3.
If you are trying to view video from a set-top box, DVD player or similar device, use its menu system to set the proper video output channel so that it matches the video connection are using. For example, if the monitor is connected to a satellite receiver via a second HDMI connection on the back of the receiver, select HDMI-2 (or similar) using the remote control for the receiver.
4.
Turn off the monitor using the monitor's power button and then restart the monitor.
5.
Cycle the power on the monitor as follows:
1.
Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
2.
Unplug the power cord.
3.
Wait 5 seconds.
4.
Plug in the power cord.
5.
Press the power button on the monitor to turn on the monitor.
One of two things happens:
1.
The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
2.
The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution.
6.
Adjust the Windows display resolution to a setting that is compatible with the monitor:
NOTE: The native resolution setting for your model of monitor can be found in the Monitor User Guide, the monitor's product packaging, and product specifications.
1.
Restart the computer and press F8 repeatedly after the first logo screen.
2.
Select Safe Mode .
3.
Windows should open showing a Windows desktop with lower resolution and fewer colors.
4.
In Windows Vista, click Start , Control Panel , and click Adjust Screen Resolution in Appearance and Personalization.
In Windows XP, click Start , Settings , Control Panel and then double-click the Display icon and select the Settings tab.
5.
Move the slider bar until the native resolution for the monitor is set, click OK and restart the computer.
6.
If the native resolution is not available from the slider bar, click Advanced Settings , click List All Modes (from the Adapter tab), select the resolution, and click OK .
If the native resolution setting is not available as a selection in Windows, you can temporarily use 1024 x 768 to complete these steps. However, you should update the graphics driver on the computer. Updating the graphics driver can provide more display resolutions to Windows; possibly including the native display resolution for the monitor.
Check for nVidia video driver updates at nVidia Home Page (in English).
Check for ATI video driver updates at ATI Home Page (in English).
Check for S3 video driver updates at S3 Graphics Home Page (in English).
Check for Intel video support and downloads, Intel Downloads (in English).
If you own an HP or Compaq computer, HP hosts video drivers and some video driver updates at the HP Software and Drivers site (in English)
7.
Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jun 15, 2008 | HP PAVILION A6230N DESKTOP PC
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Samsung LN-T2342H 23 in. LCD HDTV Logo
142 people viewed this question
Henry  Thomas
Henry Thomas
