Acer brought a new pc plugged all in. only blue light on tower on and blue light on screen flashing can u help
  • Anonymous Jan 22, 2009
    flashing blue light on pc
  • Anonymous Feb 11, 2009
    HP Pavilion a622n Desktop. Turned off and unplugged to upgrade the RAM memory. When all was done and plugged in power button flashed intermittently and PC would power on. There is a small green light in the back of the PS that also flashes.
    Sergeant:
    Champion:
  • 221 Answers
If you've recently gone for your PC, you should take NO TIME to contact your Vendor. Contact the one from whom you purchased your Computer.
GOTO WWW.SAHAJAYOGA.ORG TO ATTAIN YOUR SELF REALIZATION AND FIND A SAHAJAYOGA CENTER TO GOTO.
Posted on May 31, 2008
Acer e-510 will not start
If you have your manual, please identify which blue light is flashing.
You may want to remove the battery for about 5 minutes, and then try to boot your computer. Make sure the computer charger is not plugged in when you remove the battery.
Mar 06, 2015 | Acer Computers & Internet
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
Hello, i have a problem with my PC Model: Acer Aspire M7200 (Desktop Computer.) . I left it running over night and this moring i woke up and the power button was flashing blue, and dosnt turn on. I dont...
Hi gatisd2
PLEASE RATE MY ANSWER IF YOU FOUND IT HELPFUL
I think its gone into power save mode my does that i pull out my power cord from the tower wait 30 seconds then plug it back in....See if that helps (TURN OFF ALL POWER SUPPLY FIRST)
Jan 30, 2011 | Acer Computers & Internet
Power on blue light flashing on tower & screen - no picture
Open your computer and disconnect the power suppy on the motherboard for 3 to 5 minutes and then remove the RAM or memory on your motherboard then clean it by rubbing the pencil eraser or the rubber on the pin, After that, try to connect it all back and power on your computer. If the problem was not solve check your processor holding the heatsink if did not overheat. If it is normal just replace your motherboard because that was a problem and have damage.
May 24, 2010 | Acer Aspire™ T180 PC Desktop
I just bought a Acer 19' monitor and I'll trying to connect it to my Dell PC. It came with to cables (blue and white). The blue goesinto the back of the PC Tower but the white one fits nowhere. When the...
they all come with two cables. blue being vga, white being dvi cable. you only need to plug the blue into both ends (computer and into the monitor) and turn on. If it is still not working how many video cards are there on the computer? Do you have it plugged into the right spot and is it tight on both ends?
Jul 23, 2009 | Acer AL1916W 19" LCD Monitor
I have an Acer X1700 desktop - 3 days old by the way. Runs Vista Home Premium. 1 day after arrival, pushed power button. Monitor light is blue, flashes the Acer logo, then says "no signal" and blue light...
I would get ahold of acer. It should be under warrenty. sounds like a hard drive issue to Me. Just because it is new doesn't mean it was right from the start. My neighbour had the same problem with his acer. I told him to but a dell or hp. good luck.
Apr 27, 2009 | Computers & Internet
My tower will not turn on
It sounds as if your power supply is having issues, I would recommend replacing it.  If your good with computers, you can test the power supply: 1. Open the computer tower. 2. Find the main plug which runs from the power supply to the motherboard. 3. There should be 16 wires. 4. Find the green wire, short it to the black wire with a paper clip. 5. If the computer seems to turn on, its your motherboard having issues and you will probably need a new computer.  If it does not turn on, your power supply has failed, and you need to replace it.
I hope this helps!
Apr 03, 2009 | Acer Aspire L100 PC Desktop
Tower disc drive won't open
What bunnydawg means is it connected properly to the psu. If lights flash it could simply be jammed If they dont open up the back and check the plug with four metal points in it is in properly
Sep 07, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
