Question about Micro Solutions (224010-USA-INT) DVD±RW Burner
How do I open this unit to clean it? - Micro Solutions (224010-USA-INT) DVD±RW Burner
  • 73 Answers
It is not recommned to open any disc drive to clean it... cuz u could really do more bad than good .... the best way would be to buy u a disc cleaner ... prob the dvd disc cleaner and try that ,... if it's dirty it should clean it no prob....
Posted on Oct 11, 2010
Bmw 318ti compact engine picks up very slowly any ideas what could be causing this
it could be the throttle sensor or the MAF sensor needs cleaning, they both can be cleaned, MAF there is a MAF cleaner spray, instructions on spary can you need to follow. throttle sensor depending on the the year or engine number there is a few different throttle types. from 1997 upwards. you would need to remove the unit an open it up but clean the unit before hand and open on white paper or white cloth, when open spray the inside with switch cleaner and move the parts inside and spray, leave to dry and re seal the unit.
Jul 14, 2017 | BMW Cars & Trucks
My Marey tankless water heater will not ignite for the shower, but will forthe faucets. Have changed batteries, cleaned the filter and had the showerhead cleaned. Local plumbers will not do...
Most on demand or tank-less units require a minimum flow rate before the unit will fire up, they designed them that way so small water leaks (drips etc.,) keeps the unit from going on needless;y. Try opening the shower hot water fully and see if it comes on, If it does, try closing it slowly to see where it shuts off. Make sure your shower head is clean and not blocked with calcium, which will restrict the water flow. You could also try changing the shower head to one that allows more gallons per hour flow rate. Also make sure the cold inlet and hot outlet valves on the unit are fully open and the diverter on the shower is fully open as well.
Mar 24, 2015 | Water Water Heaters
How do i clean a purge unit on mp610 canon? where is it located?
the purge unit is located where the print head rest itself.. normally it's under the right side of the printer.
You will need to remove the cover in order to clean the purge unit, you have to be very careful as the purge unit might have small spring and if it's not fitted correctly, it will damage the purge unit.
Easiest way to clean it is switch on the printer, and open the front or top cover...let the print head move to replacement position then pull the power out and clean the purge unit. It's a messy thing as it will be fill with ink. U can clean it using tissue and moist cloth... apart from that, don't think you can clean much of it unless you are able to open the whole printer up then you will have a better view and space to clean it.
May 25, 2010 | Canon MP610 Photo All-In-One Printer
Saying lens cap on won't record!
Your iris stuck up contaminated by the grease of lens mechanism. To clean, the unit must be opened up to where you can access the lens assembly and remove the iris unit assy then the two curtain(shutter) and clean with video head cleaning solution or any alcohol base cleaning agent. Re-assemble it but test the shutter first before assembling the camera completely. To test, open the shutter(curtain) manually by your finger and must close freely once released. Also clean the surroundings for some oil near the iris unit to avoid it from coming back to the shutter.. Good Luck
Mar 18, 2010 | JVC Everio GZ-MG21 Camcorder
CD Stops playing in middle of nowhere
Try cleaning the laser using CD Cleaner, if still won't work.You can cleaning it by your self( if you like !!)
The procedure is:
Open the CD case,by removing all the screw( unplug the power cord first).
After opened, see for the disc unit, it's mechanical unit, try opening it by removing the screw, unplug the driver cable unit and laser pickup ( very thin cables).
Then remove all the mechanical unit from the CD case, now open this unit by removing the top screw, then pull out the Disc Tray by rotating white gear under the tray.
Now you can see the lens, use a clean and soft clothes or cotton buds, use alcohol to clean the lens first, after using alcohol, use dry clothes or cotton buds to wipe it up again until the lens dry.
Resemble all back together and try operate it.
Hope it works!!!
Dec 08, 2009 | Audio Players & Recorders
CONSOLE OVERHEATS WITHIN A FEW MINUTES OF BEING ON
Open unit up and clean dust and debris off heatsink fins. Outer case opens much like a clamshell once screw are removed from bottom. Plastic seam and end pieces pop out with flat screwdriver (carefully). Inner unit can be removed and opened easily after this. Once cleaned and reassembled, try to keep unit in clean, cool, smoke-free place with good air circulation for best life and performance.
Nov 25, 2009 | Microsoft Xbox 360 Console
Brother printer mfc 4100 is printing light though the drum and toner cartridge have been replaced. Someone suggested that the laser is dirty..but I do not see how to clean it. I assume it is inside the...
yes mr it is problem your Lser unite laser mirror is dirty .please open your printer cover full body laser unite stand middle position open laser unite black cover and clean mirror tisupaper,laser drum unite six corner replactor mirror clean then solve your problem.If you are not success then toner unite ground point chach or ccd sensor clean
Aug 13, 2009 | Brother MFC 4100 Printer
POOR PRINT QUALITY
perform a head clean, deep clean through inbuilt cleaning program of your printer
May 13, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Dec 31, 2007 | Kyocera Mita FS-1920 Laser Printer
Micro Solutions (224010-USA-INT) DVD±RW Burner Logo
35 people viewed this question
Top Micro Solutions Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a Micro Solutions Computer and Internet Expert? Answer questions, earn points and help others
