Question about Desa International Reddy Heater® RHER70CT
The heater fires and then rund for about 15 seconds then shuts off. I suspect the circut board or the photo eye where can I get these parts?
  • 232 Answers
The problem could be what you suspect or it could simply be an air pump adjustment situation. Instruction for setting the pressure and replacement parts can be found at www.reddyparts.com.
Posted on Oct 14, 2010
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
Will not stay running
first plae to check is the electric eye. it has to tell the control circut that it sees good flame. next check to see that the fuel filter is clean.
Jan 18, 2010 | All-Pro Forced Air Kerosene Space Heater...
My heater fires up after 5 seconds and then dies out.
Locate and clean lens on fire eye. If heater will run with fire eye wires connected with a jumper then replace eye.
Sep 27, 2009 | Reddy Heater 60,000 BTU Kerosene...
The heater runs for approx. 7-10 minutes then shuts down
very rarely it's the circut board.most likely it will be the photo cell.does you photo cell have one blue wire and one white wire????or is it two blue wires,they are two differant photo cells.if it's two blue wires you nee to check the air pressure.it's very important.if the pressure is wrong it will not work properly.you need a gauge to check it.
Mar 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Failure to maintain flame @ low temp ~-25 and below
some photo cells the eye gets dirty with condensation due to the cold have found this on wood kilns when temp drops try cleaning ,or just by pass to give you some heat , you might have to clean it a few times to clear it ,
or you could remove eye at low fire when heater warms up try replacing eye , this is going on what we have to refire wood kilns when it was cold here acouple of weeks back . hope this helps you
Jan 11, 2009 | Heating & Cooling
Reddy heater 110btu kerosene starts and shuts off?
I would say the thermostat is bad after reading your problem over several times. There is no reason to suspect a wiring problem, and I strongly suggest you don't bypass anything! A fire or explosion could result. Replace the thermostat as a probable cause.
Ray
Dec 08, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Ignition problems
what kind of ignition is it? spark or hot surface igniter? the photocell just detects the flame. it causes the controller to go into lockout if it doesn't detect a flame. a hot surface igniter uses 120 volts to operate, again off the controller.
Nov 20, 2007 | Reddy R155D Utility Heater
Reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Nov 02, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Desa International Reddy Heater® RHER70CT Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
