Question about Brown Stove Works TEM721-DK Electric Single Oven
OVEN DOOR CAME UNHINGED, CANT GET IT TO GO BACK WITH THE HINGE
I have unhinged the oven door. I cannot get it back on.
how did you unhinge it .usually they need to be semi open to put the door back on .
Jan 17, 2016 | De Dietrich Ovens
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
How do I re-insert the Thermador oven door so it is properly in place and functional? Issue cropped up when someone cleaning it put too much force on the door and it became unhinged on one side. I was...
Sorry to read about your problem, I hope this helps you out.
this takes alot of practice, really hard to explain..i suggest you call a service company....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Took the oven door off and now cant get it back on
Typically one cannot fight the hinges while putting the door on.
USUALLY you can move a hinge down/open and there is a hole to put a nail through to hold each hinge down while you get the door in place.
Nov 20, 2009 | Whirlpool SB160PEE Gas Single Oven
I cleaned my oven and cant get the door back on
Pull the hinges out to the first stop, where you set the door when broiling, and just lower the door onto the hinge bars.
Nov 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Jan 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Brown Stove Works TEM721-DK Electric Single Oven Logo
181 people viewed this question
Top Brown Stove Works Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Brown Stove Works Oven Expert? Answer questions, earn points and help others
