Question about Coleman Roadtrip Grill LXE 9949-750
What to do about an high pressure leak at the valve on Coleman road trip grill.
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
cadesertmax
  • 274 Answers
SOURCE: road trip grill loses heat after 5 to 10 mins
You could have a bad regulator.
Posted on Jan 10, 2010
  • 494 Answers
SOURCE: Where can I get the fuel line that connects the
Take the entire grill to your local propane company, so they can look at it and replace it on site for you. Call around first, as some places no longer have a repairman on site at any given time.
Douglas
Posted on Sep 09, 2010
  • 32 Answers
SOURCE: I have a road trip
There may be some grease or other debris around the problem burner. It could be causing a high flame. Clean around it well, then turn it on and leave it running for a minute or two.
Posted on Mar 29, 2011
  • 4736 Answers
SOURCE: coleman road trip is hooked
Lloyd, the regulator isn't working. But the problem generally, easily solved, if you follow the directions below.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! And thanks for choosing FixYa.
Posted on Jul 28, 2011
What is the chain for in a coleman road trip sport grill
It is called a Match Extension. It lets you use an ordinary book match to light the burner by placing the lit match in the wire loop and holding it near ththe burner
Jun 10, 2012 | Coleman RoadTrip Sport Grill 9944-851
Coleman road trip is hooked to a 20 lb tank but when turned on, small amount of gas comes, then quits. appears to me as if regulator is not working. cannot use grill at all. lloyd
Jul 28, 2011 | Coleman Roadtrip Grill LXE 9949-750
We own a coleman Road Trip tabletop grill model 9940-799. We have used it approximately 15 times without a problem. However, when we went to use it recently the knob will not turn after you push it in. The...
Other than replace the burner valve, there's not anything you can do. Apparently. it got jammed somehow, perhaps during the it's time in storage between uses or someone tried to force the valve.
Who knows? In any event, if you want to find the replacement part, go to the following link.
http://www.coleman.com/coleman/parts/Productimage2.asp
If you don't see the part needed ( the numbers on the exploded view of parts are incorrect) call Coleman 1-800-835-3278.
I hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | Coleman RoadTrip Party Grill 9940-799
I have a road trip grill model 9949, one burner burn high and yellow,the other is normal.
Mar 29, 2011 | Coleman 9928A50 Propane Grill
Where can I get the fuel line that connects the gas regulator to the valve assembly for my Coleman Road Trip grill?
Douglas
Sep 08, 2010 | Coleman Roadtrip Grill LXE 9949-750
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman Roadtrip Grill LXE 9949-750 Logo
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
