The computer what let me restore or install new programs i keep getting error code 8100202 and message say shadow restore not working or samething like that
    President:
  • 2,340 Answers
Read these help links:-
1. http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/953b0ce7-0443-4a6c-bb50-c5b4d7deafc7
2. Use SFC /Scannow to Repair Protected Windows Operating System Files @ http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm
3. Assuming your PC is secured with security programs like AntiVirus, Malware & Spywares utilities.
Hope it helps.
Posted on Oct 11, 2010
Error code ox0 on acer aspire t690
which application gives this error?
when do you get it actually?
Jul 10, 2008 | Acer Computers & Internet
WHEN YOU WANT TO PRINT THE MACHINE DIDNT WORK
error code 5100 points to a windows program error
1. you can uninstall the printer then reinstal the printer if it does not work
2. you will have to restore your system to earlier backup (start.. accessories..system tools.. restore) your post is dated 9 Feb if you restore you will lose any new program you have installed but you will note lose any data like doc photos
Feb 09, 2014 | Canon PIXMA MP230 Multifunction color...
Sim 3 into the future installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Extended Attributes Are Inconsistent Error Message error?
There are two (2) ways to fix Extended Attributes Are Inconsistent Error Message Error:
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Extended Attributes Are Inconsistent Error Message ) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 20, 2014 | Computers & Internet
I have windows xp an error message box pops up that says at the top message from webpage [object error] it wont go away after xing it hitting ok or alt control delete. Everthing is locked up depending on...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer this may vary depending on your computer and operating system If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details or You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps. Hope it helps.
Jan 05, 2013 | Computers & Internet
I have used trutech/camarades webcam for years its version 2.2 which is the best version. When i try to open the program i'm getting an access violation.
I need more info... What is the operating system installed on your computer?
Have you every run Windows update recently?
Is this the first time you install this software?
Give me the brief description about your system's configuration.
There must be some error code/s with the "Access violation/denied...." if so, give me the full error message, there are several similar errors with similar codes, but the fixes and diagnostic measures are different...
Thanks...
Oct 08, 2010 | Computers & Internet
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Bad image error message
Upon startup, one of the F keys, usually F4 through F8, will bring up a system repair screen, with a lot of options. Pick "Restore and Backup". Then Restore your computer to an earlier date. This will keep all your files and programs, and restore your registry and drivers to an earlier date when they worked. You probably got a virus, and this will get rid of it. Good luck, and hope this helps.
Jul 08, 2010 | Toshiba Satellite P205D-S8804 Laptop
I have an error message - ControlCenter2.0 -
...so re-install the software like it says, or try a system restore to a few days ago when it was still working:
in XP:
"Start"
"Programs"
"Accessories"
"System Tools"
"System restore"
"Restore My computer to an earlier time".....
Vista:
Type "Restore" into the "start menu search box", select it, and follow the prompts.
Jun 11, 2009 | Brother MFC-5440CN All-In-One InkJet...
Error message
Hi there
It has something to do with your antivirus i think, If you used the System Restore function of your computer, it is very likely to have installed an obsolete antivirus program. Almost all computers now come with an antivirus program some sort installed, and the Restore disks (or built-in System Restore) will reinstall it automatically.
Open the Windows Control Panel, check your list of installed programs, and see which antivirus program you have. Uninstall all but one of the antivirus program's.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
