Question about Kenmore Washing Machines
The washer stopped all of the sudden. It was full of water, but even when I unplugged the washer and recycled the machine, it would not fill up. It makes a humming noise when I try to start the machine, like the pump or motor is bad.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
If it fills and drains then I would suspect the motor coupler is bad, if it's a direct-drive washing machine. Most of them are, kenmore 80 or 90 series.
Posted on Oct 10, 2010
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
May 21, 2010 | Washing Machines
Washer won't stop filling even when unplugged?
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Apr 08, 2010 | Kenmore 44832 Front Load Washer
My GE washer wont stop filling in any cycle. Even if you pull out the plug. Leaks everywhere. I blew into water level switch hose and it clicks. Model number WBXR1060T. Thank you
If water continues to fill and you have unplugged the washer from the wall then your fill valve is stuck open and needs to be replaced. Turning off the water at the wall faucet should stop the water. The fill valve is what the hoses are attached to at the washer.
Feb 02, 2010 | Washing Machines
Water fills washer even when it is unplugged
Replace fill valve. It is located where the water hooks up to washer. Easy to change. The valve gets plugged with sediment and needs to be replaced.
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Warer stop on fill up
  1. try to recycle the level control hi and low. Try the hot and cold to try and get more water in the unit. JOHN-LA.
Aug 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
159 people viewed this question
Sal De
 Brian Main
Brian Main
