Question about Kenmore Dryers
It heats but drys slow - Kenmore Dryers
It drys so hot it damages my cloths
There is a temperature sensor on the case that houses the heating element. It is bad and that makes it put out straight heat all the time
Sep 27, 2012 | Maytag Neptune MDE4000 Electric Dryer
Drys too slow
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Whirlpool LER7646E Dryer
What's the difference between dry and cool setting and when should dry be used
Dry is a dehumidifier option. There is a heating element in the unit to heat the cold air back up. The cold evaporator coil causes the moisture in the air to condense on the coil (this is why the AC leaks water) and the air coming out of the vents will be cold. If you are not wanting to lower the temperature in the room but want to take out the moisture then use DRY. All ACs take the moisture out of the air when they are on COOL. So, COOL drys the air and makes it cold. DRY drys the air but warms it back up before sending it out the vents.
Jun 14, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
My new electrolux gas dryer doesnt get hot enough so it drys too slow.
contact the store you bought it from for service
Apr 09, 2010 | Dryers
Whirlpool Gas dryer only dries on high and timed setting
i would start with my exhaust vents,,if it drys on high that means we have heat,,the other cycles give last heat,,,
Jan 01, 2009 | Whirlpool GGQ8831L Gas Dryer
My hotpoint tdc32 does not heat up just drys cold
Friend,
huuum At your service!
You aid, my Hotpoint tdc32 does not heat up just drys cold
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Sep 12, 2008 | Hotpoint Dryers
Whirlpool dryer
the temperature switching control has become very weak so change that switch
Jul 29, 2008 | Whirlpool LER5636P Electric Dryer
Dryer intermitantly drys.
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
