Question about Maytag Neptune MDG5500AW Gas Dryer
Why my maytag Neptune gas dryer stopped heating up?
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 11, 2010
Describe your Neptune MDG9700A Gas Dryer Problem igniter clicks a couple of times then stops, burner does not light. had code of 02
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Maytag Neptune MDG9700A Gas Dryer
My Maytag Neptune gas dryer has stopped heating The button pannels turn on, dryer spins but no heat I cleaned the vents Model no. MDG6800AWW How do I fix it? Can I repair it myself? Is there a...
When the dryer wont heat it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Dec 30, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Neptune MDG5500AW Gas Dryer heats up for a few minutes then stops heating. any ideas? thanks!
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
You will also find videos of disassembling most style dryers at the same site.
Nov 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stopped heating
heatman101
ttyyt
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat and can't get front off
remove the door and the screws on opposite side pull front away and down remove corner brackets "L"s and raise top..unplug of course !
Jun 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
157 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
