Question about Jenn-Air JCB2389G Stainless Steel Side by Side Refrigerator
My refrigerator has been getting warmer & warmer over the past week,the freezer has been affected also. About a year ago,Maytag sent a letter that a part that helps the motor was defective & I had to buy the new part & had it installed.
    Genius:
  • 1,478 Answers
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the other to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it. This are are the general procedure for troubleshooting refrigerator not cooling. with all this, you should be able to identify and fix the problem.
Take care.
Posted on Oct 11, 2010
Refrigerator and Freezer are not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 25, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag MSD2356AEW refrigerator freezing up
You did not clarify , if the board was changed or not . You only have 2 parts to the defrost system , as the defrost heater AND bimetal , come togather . I would start with the heater/bimetal part first .
Pt number 61006198 Heater and bimetal
Pt number 61005988 Adaptive defrost board
The bimetal , is the 1" cylinder , clipped to the top of the coils , and heater , at the bottom of the coils .
Oct 07, 2009 | Refrigerators
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
Fridge side not cold enough but freezer ok.
It is possible that your adaptive defrost assembly found inside the fresh food section and behind the control panel is defective. If not we need to check the defrost heater and the defrost thermostat. Sea Breeze
61005988 Adaptive Defrost Assembly
Jul 25, 2009 | Refrigerators
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerator does not cool. Electrolux FRIGIDAIRE we moved into a new construction condo and all appliances were new we liveed in it for 6 weeks frige was fine but loud it is a model GLRT 13TEW4 serial...
If the unit is less than 1 year old call Frigidaire factory service. In the mean time check in the back of the freezer or in air channels for frost build-up. It may indicate a defrost problem or air leak. still best to have factory tech check if in warranty.
J
Jun 13, 2008 | Refrigerators
Maytag side by side not defrosting....
You have the signs of a defect in the defrost system which is indicated by the frost buildup on the back wall. This also affects the refrigerator. Call the dealer you purchased it from and request a service tech.
May 01, 2008 | Refrigerators
Jenn-Air JCB2389G Stainless Steel Side by Side Refrigerator Logo
258 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
