Question about Toshiba Computers & Internet
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it doesnt load or anything....i cant afford to do a system restore because i have a lot of information on my computer that i didnt save
    Brigadier General:
  • 6,966 Answers
with the indulgence of xx....
Lost you in the Live Session/Chat. In any case am posting copy of the session with my suggestions.
You are now in session with chris_cox_13
Benimur says:
Benimur says:
How can I be of assistance pls?
Benimur says:
Still there?
Benimur says:
In any case, reading your original posting, it would seem that your OS is having a difficult time loading due to failure in installing one of the PC's devices.
Benimur says:
One possibility is a USB device that is not responding such as a flashdrive, external hard disk, printer, camera and others. Try booting without any USB attached.
Benimur says:
This page might shed additional insights >
Benimur says:
An alternative is to try and boot into Safe Mode to allow the OS to continue installing/running the drivers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
  • 55 Answers
Where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
Windows will not start up or launch start up repair
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
We are trying to upgrade an inspiron 1720 to 4gb ram (2/2gb chips) when we turn it on after installing the second one we get this: "error code 0148" the next line is: "msg error code...
It sounds like the New 2GB RAM module is either faulty or incompatible.
From your notes it appears the system functions fine with the original 2GB module and 1 GB module. Have you tried replacing the original 2 GB module with the New 2GB module and see if you have the same issue? Also will the system boot with just the new 2GB module?
Recommended ram for that system is: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Jul 19, 2011 | Dell Inspiron 1720 17" Widescreen...
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Windows vista will not load, when power is turned on, the first screen is windows error recovery with options Launch Startup Repair or Start Windows Normally, start windows normally shuts computer down
Try a recovery . If that does not work try a hard drive test . If that passes reinstall the os . If it fails look at options on how to change the harddrive .
Oct 20, 2009 | Acer Aspire 5920-6727 Notebook
Error code 2000-0146
I had the same problem and came across the following solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Aug 03, 2009 | Dell XPS M1530 Laptop
Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
May 09, 2009 | Computers & Internet
Windows failed to start !...
if you had the recovery disk it would not clear the c drive it would just set it back to when you got it but the programs would still be there this computer i a,m on know had trhe same thing done to it and i was able to recover it without losing any info if you can get into bios and set it back to defaut or fail safe options you may be able to get going from there
Feb 17, 2009 | Acer Aspire 5920-6727 Notebook
Windows did not start successfully. "Start Windows Normally"
Normally Windows gives this error when a new program or device driver has been improperly installed. When presented with this screen upon boot up, select "Start Windows Normally".
Should Windows fail to start normally, the next solution is to allow Windows to repair itself, (assuming that is an option).
Should Windows not offer to repair itself, you may get the option to restore Windows from a previous state. Select YES if this is the option and pick a date in time when you know it was working properly. The date may be slected from the menu.
Hope this helps you.
Dec 29, 2008 | Gateway Computers & Internet
Wont turn on properly
Press the F8 key about 7 times slowly when you see the DELL logo screen after the restart.
Select the option Repair my computer.
The start up and repair window would come up follow the wizard . It should fix the issue .
If it does not , it would give you more options to try repair the system. Try system restore from the options.
If none of the above steps work , it time to reset your computer to factory settings. A corrupt vedio driver update, is the cause of this problem
Jun 02, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
