Question about Sony Cyber-shot DSC-W35 Digital Camera
Format error I Have Sony cyber-shot W35. I insered a sony memory stick pro duo 2GB into it and then I turn on the camera, it gives " FORMAT ERROR" It works fine without memory stick.
  • 1 more comment
  • elli123 May 31, 2008
    I do this, but unfortunately the problem persists. This is the second memory pro duo and the probl. is the same.
  • elli123 Jun 01, 2008
    Memory stick is Ok. It works in other cybershot and the cybershot works fine without memory stick, .............but together NO.
  • Nick_28 Nov 22, 2008
    After 1 GB of photos (I have a 4 GB card) it got this Format error message and I lost all pictures. Even if I formated many times the card, the same problem appeared. What should I do?
  • 10,594 Answers
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
Posted on May 31, 2008
  • Shahid Electronics
    Shahid Electronics Jun 01, 2008
    Please check memory stick in other cybershot just to make sure that memory stick is fine n Ok.
    If it founds Ok, means camera memory slot has incorrect pins inside. Thats why it doesn't make proper contact with memory stick for data traveling.
    Shahid Electronics Jun 02, 2008
    Alright, seems memory doens't match any more with your cysbershot, get another memory stick, its not so costly item. Or repalce it with friend's memory stick.
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony dsc-s730 format error
Download the pics to your computer using a separate memory card reader. Then, format the card in the camera.
Sep 22, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
FORMAT ERROR C:13:01
Please format memory stick by going to camera menu > format ption.
Oct 05, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Sony memory stick pro duo
Well alot of the time there is a issue with the formating that the camera does on the stick and also when formating it on the computer it formats it another way as well. some in FAT and some in FAT32 this is ushally a error for the most part I would definatly plug your duo stick into a card reader and then go to my computer and the find the drive that the stick is in and right click on it and go to properties and do a error check on the stick to make sure that there is no errors. and if you can defragment after the scan then by all means do it and then format the card and try it and hopefully it will work out to your advantage.
*note this problem seems to only happen with the non branded duo sticks not the sony branded ones.*
Aug 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Jun 12, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
No piks showing
The memory card can't be more then 2gb...the camera won't support more than that. Have you formatted the memory with the camera? If not try that, don't format the card with your computer.
May 05, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Memory card
Try and format the card with the camera. Got to use the menu settings for that.
Apr 19, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Problem with a memory stick
You need to format the memory card within the camera, else you will receive this error.
Apr 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
425 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
