Question about Canon MX700 Office All-In-One InkJet Printer
Error 6502 every time I load a new ink tank I get the dreaded error code 6502. In the past the code finally after many attempts of turning the machine off and on the problem went away....but not this time. I know the thing still works because it was working fine until I changed the tank and I KNOW I installed the tank correctly
  • 6 more comments
  • natalievh Sep 04, 2008
    I'm having the same problem. I replaced the ink cartridge and now I keep getting the Error 6502. I tried to do the suggestion below, but I do not have a resume button. I have a MX700 so I don tkwno why I dont have this button. What do I need to do?
  • Anonymous Sep 21, 2008
    does anyone have the correct answer to this problem...
    please advise...
    help
  • jfleming215 Oct 11, 2008
    Not only do I have the problem, but when I took the unit to a repair center they told me they could not get the unit to fail. They claim they printed a bunch of pages, and it was fine. I picked up the printer, bring it home, and SAME ERROR.
    The solution here suggests pressing a "RESUME" button. My MX700 does not appear to have one... ???
  • aynaa Nov 23, 2008
    i have the same problem and i did everything i can to fix it and nothing works! this printer sucks!
  • Anonymous Dec 10, 2008
    WHEN I REPLACED THE BLACK INK TANK, I GET A MESSAGE THAT IT DOES NOT RECOGNIZE ANY OF THE TANKS AT ALL. I HAVE UN-PLUGGED MACHINE SEVERAL TIMES AND I DO NOT HAVE A "RESUME" BUTTON
  • dkgehris Dec 15, 2008
    Tried all the unplug and push the reset/button suggestions but no luck. Does anyone know how to fix this other that buying a new printer.?
    ANY SUGGESTIONS on a BETTER printer?
  • Anonymous Apr 04, 2009
    None of the reset ideas work for error 6502, and yes there is no resume button. It just goes away over time.
  • 3 Answers
We just had the 6502 error after replacing 2 of the 4 ink cartridges. We had removed the cartridges to take to the store. When we replaced with the 2 new ones, everything was lit-up fine, but we kept getting the 6502 error. We tried unplugging, hitting the reset/stop (which just beeped at us - never did anything...) and different combinations of removing/installing all the ink cartridges AND the print head. Nothing worked. We eventually left the cartridges in-place and unplugged the unit for the night.
The next morning, plugged it in and it STILL had the 6502. But then turned if off again, waited an hour or so and when it came up after that, it gave an error that the 2 ink cartridges we didn't replace were not recognized. We opened the top and those two cartridge lights were blinking. We re-sat them and all is now good (knock on wood!)
We're thinking that taking the cartridges out to get replaced (they were out for about 1 1/2 hours) may have led to some ink residue drying in the unit....???? But when we have to replace any cartridges in the future, we plan on buying it FIRST and THEN swapping it out immediately with the empty one.
Posted on Sep 01, 2009
  • 4 Answers
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
Posted on May 31, 2008
  • dru24 Apr 18, 2011
    There is no RESUME BUTTON!!!!!!!!!!!
I turned off my printer. Then I lifted the lid, then the cover so you can get to the ink. Turn on the printer, while both are open and wait til you get the " Cover is open" on the display screen. The ink cartridge will stop in the middle with all light lit. Then shut the cover and wait til it resets.
Posted on Mar 29, 2009
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have cannon IP3680, but from today it's making problem (Service error 6502), would u please tell me a easy way to solve the problem...
The error 6502 is an "Ink tank position sensor error". It may be that the sensor is dirty and needs cleaning. Make sure you haven't got any bright lights shining into the printer.
Mar 01, 2011 | Canon Office Equipment & Supplies
I have a Canon MP510 printer and have changed the print cartridges many times for refills but am now always getting error 6502. I've tried turning it on and off, unplugging it, holding down power button...
hi,
you mentioned that you turn off and on these is on of the solution of your problem
but in your case it doesn't work
error 6502 arise when ink tanks not snapped properly
follow the steps below
  1. Confirm that the printer is powered on and pull open the paper output tray .
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place.
note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
5.Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
1 -tank installed properly
2-not installed properly
6. check the status of each ink tank according to the way its lamp flashes.
  • - On: The printer is ready to print.
  • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • - Off: An error has occurred and the printer is not ready to print.
  1. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
  2. regards,
  3. cseian
Dec 16, 2010 | Canon PIXMA MP600 all-In-One InkJet...
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6502
That error says it's a ink tank position error, make sure there are no paper scraps in the paper path, and you might clean the encoder strip with a q-tip and water. Make sure the carriage can move freely from one side to the other.
Aug 09, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Oct 03, 2008 | Office Equipment & Supplies
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
546 people viewed this question
old marine
old marine
