Question about Texas Instruments TI-89 Calculator
My TI-89 will not turn on or respond in any way. The last time I used the calc was 4 months ago. I tried to turn it on a few days ago but it would not work so I changed the batteries. That didn't work and neither have any of the solutions mentioned online. What can I do?
  • 37 Answers
Take out one battery. While holding the "On" button, put the battery back in. I can honestly not explain what happened, but it has happened to me multiple times as well. You might have to do this more than once, but within a few attempts, it should start working again. Tell me how it works out, and hope this helps!
Posted on Oct 12, 2010
  • wimberleytex Oct 17, 2010
    This still didn't work. Do you know of any other solutions? Since I bought the calculator in February, do you know if Tx Instruments will replace it?
  • Isaac Vogler Oct 17, 2010
    I cannot tell you for sure, but if so long as you didn't do anything outrageous with it (dunking it in water or throwing it against a wall), and you have the paperwork that came with it, you have a very good chance of getting a replacement. Sorry that I can't be of more help.
    OH! I didn't think of this one. Turn it on, then try to lower the contrast as much as possible. What might be happening is that it does turn on, but you can't tell, because the screen is too light.
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
Jun 01, 2017 | Texas Instruments TI-89 Calculator
My ti89 calc is not working since a year what is the problem? how can i solve in india?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the 2ND key. Tap the Up-arrow key several times and see whether the screen becomes legible.
If that doesn't do it, please respond to this thread and we'll go on from there.
Jan 24, 2012 | Texas Instruments TI-89 Calculator
My TI-89 calculators finance app is giving me the wrong answers by a few 1000 or so and increases how far off it is the larger the figure
Make sure your decimals are set to the correct number.
And also you can perform a factory reset on the unit to make sure all is back to normal.
Just be aware that it will delete any information which you have stored into your calc.
Resetting
After using the TI-89 and changing modes several times, you may set the calculator back
to all default modes by pressing 2nd 6 (MEM), F1(Reset) and 3 or by highlighting
3:Default and pressing ENTER. To reset all memory press 2nd, 6 (MEM) then F1(Reset)
and select 1: All.
Feb 23, 2011 | Texas Instruments TI-89 Calculator
My ti-89 wont turn off
if the second key is working try to reset the TI89
take out 1 battery
Hold Left Right Arrows 2nd and on
Put back the battery when the screen will reset leave the keys
this should reset the Calc if it will not help there is a problem with the hardware
Hope it will help
Dec 25, 2010 | Texas Instruments TI-89 Calculator
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
Calc will not return a value im looking for when entering N,PV,FV
Having gone over a month without a response, I assume this is no longer a problem.
Apr 12, 2010 | Texas Instruments TI-89 Calculator
The TI-89 Titanium calc. purchased in Oct. 09 won't turn on
Try to increase the contrast
1. Turn it on
2. press [2nd] and release button
3. Press [UpArrow] and release button
4. Repeat steps 2 and 3 until contrast is adequate.
If that does not work use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html
Install it on your computer and run it to oppen the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK..
If all that does not work, then it may be time look for a repair shop.
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
Hope it helps
Apr 05, 2009 | Texas Instruments TI-89 Calculator
Darken screen!!!
reset your calc, press 2nd left right on simultaneously. it should work.
Apr 25, 2008 | Texas Instruments TI-89 Calculator
Ti-89 Doesn't Turn OFF!!
1) Update the OS from the TI site.
2) check if button is sticking(not necessarily just the plastic button, but what it hits on the inside... you can clean the contacts on the inside of the calc with a Q-tip and rubbing alcohol.)
I don't have much experience with this specific calculator but those are my best bets.
good luck
-Saik0Shinigami
Oct 31, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
93 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
