Question about Cameras
Pentax K100d super
I have a sirius 18 to 28 mm ka mount lens jammed on my pentax k100d super
  • Shrimpo May 31, 2008
    Hi folks,
    Shrimpo here. I just fixed it. I used an engineers feeler gauge. The gap between the lens and the camera body would accept up to a ten thou feeler gauge. The one that fixed it was a three thou gauge. I needed to adapt it by cutting the end off square, tapping the end with a small ball pein hammer to make a slight ridge and then filing the gauge down to almost nothing at the tip. It worked a treat, slipped the spring loaded pin of the lens back into its seat and off came the lens.
    Anyone with a similar problem can leave a message and i'll come back with full details.
    Shrimpo
I fixed the problem. It was caused by an extra little pimple on the sirius lens slipping into the auto focus indent indent on the camera body.
It is possible to get up to a ten thou engineers feeler gauge into the gap between lens and camera body although the one that did it for me was a three thou gauge.
I needed to cut the feeler gauge square at the tip and then, even though it was only three thou, I hit the tip by resting on a vice and tapping with the ball end of a small ball pein hammer. This caused the tip to form with a small curve. I then used a tool makers file to smooth the end down to almost nothing.
Turn the camera AF MF switch to AF to raise the screw. Fiddle the feeler gauge into the slot between body and lens just near the AF MF button and very gently probe the gauge. You are trying to get the little curve you made on the feeler gauge to slip over the pimple on the lens.
Its a very nice feeling when the gauge slips right in and the lens comes free.
The next proceedure, if you want to use the lens, is to unscrew the aluminium mount at the end and remove the offending pimple on the lens.
Posted on Jun 02, 2008
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
K100D AF/MF SWITCH STUCK IN AF
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
Oct 04, 2008 | Cameras
Won't focus or take picture
Try cleaning the contacts on the camera body with a cotton swab lightly dampened with rubbing alcohol.
Jan 05, 2010 | Pentax K100D Digital Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
New SMCP-FA 50 1.4 will not work on my K100D Super or K10D
You are probably right - it sounds like it is not connecting right - I would take it and the camera to the store and check out another lens!
Dec 29, 2008 | Pentax Normal SMCP-FA 50mm f/1.4 Autofocus...
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Aug 04, 2008 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Lens
If this is a manual focus lens, you will need to do two things (and an optional third thing.)
1) On the side of the camera, you have to switch the focus mode switch from "AF" (Autofocus) to "MF" (Manual focus) . . . Yeah. I know, you probably already did that. <grin>
2) When you press Menu, go to the Custom Setting and change the Allow aperture setting to on, so that the Pentax K100D will then work with manual control of the aperture ring. You need to do this or the K100D will not work with manual exposure lenses (M lenses) or even autoexposure lenses (KA, KA2, FA, etc.) when you move the aperture ring from the "A" position to one of the manual aperture settings!
3) This is optional, but in the Custom Setting you can also turn on the Fl in manual focus mode, so that even though you don't have autofocus capability, you will get a beep indicator when you have successfully managed to manually focus your lens.
I have a few nice manual focus lenses that I have a lot of fun playing with on my K100D.
Take care & Happing Imaging!
Glen
Jun 09, 2008 | Pentax K100D Digital Camera
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
