Question about Midland Radio Communications
Poor TX RX range
Hi, Eddie here writing from Germany..... when talking to work mates from my truck they say that I am very quiet to them over a distance of about 2 miles. Also I can be driving behind a work mate having a conversation without any problems but when we go our different ways I lose contact after about 3 miles....if that.
I have a brand new Sirtel Santiago 600 antenna (apparently very good) approx 1.5m on the cab and a second hand Midland 48 Plus 80 channel CB
Some one mentioned modulation....does anyone know how to adjust the modulation on one of these?
Would it make a difference if I changed the set to a 40 chanel version?
Shall I sell the cb and buy a brand new one :-) ?
Thanks in advance, Eddie.
  • IamEddie May 31, 2008
    Hi Benimur,
    thanks for your advice & tips.
    Metal mounting - yes.. got that already.
    PL connectors - I'll have to have a look at them because the antenna did not come complete and I had to connect them to the cable ends myself. Might be that I haven't got enough wire showing through the hollow points.
    SWR - Already done....just bordering on snipping the end I think..if I read it correctly, but I suppose if the PL connections are not properly assembled then the SWR reading is out the window anyway.
    Power mic - Good idea...what about an antenna amplifier? I read on another forum this might help....any advice on them? My antenna has a 300W output if that means anything for when/if I buy an amplifier.(can you tell by now that I haven't really got a clue about CBs)..I just know how to use them.
    I'll have to wait until Monday when I'm back to work but I will get back to you and let you know how things went.
    Thanks again for your fast response. Eddie.
    Brigadier General:
  • 6,966 Answers
Since your concern is both on receive and transmit, the common denominator would be the antenna system. The antenna should have a metal mounting to serve as the ground plane. Said mounting/ground plane must be electrically grounded to the rest of the truck. The next area to check would be the PL-259 connector. It should be soldered/connected right with no shorting. Next would be the cable which should be low loss RG-58. Last to check would be the SWR of the antenna. Most mobile antennas could be fine tuned to a specific frequency/channel by adjusting its length. There would possibly be 1 or 2 Allen screws for this purpose. In some cases, it may be necessary to trim off a few mm of the rod.
On your concern re modulation, am afraid that your radio has built-in limiter so as to prevent over modulation and comply with European restrictions. Additionally, the Midland 48 Plus has been programmed to transmit only 1 watt in AM (4 in FM) when the display shows D or D2. Additionally, you might want to consider a power microphone.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
  • Louie  Role
    Louie Role Jun 01, 2008
    Hi again,,
    Depending on the laws governing radio communication in your area of operation/country, amplifiers may or may not be illegal; hence this has to be taken into consideration - what might be OK in Italy is not necessarily OK in Germany.
    In any case even having said that, CB amplifiers are designed to increase the RF power output of your transmission from the stock 1 or 4/5 watts (again depending on the country of use or whether AM or FM) to anywhere from 10, 25, 50, 100, 500, 1KW. Some known brands in the 100~150 watt range are Palomar, Black Cat, SoundAir and RM (Italy). One tech advice if and when you will be using an amplifier, ensure that on the CB radio to antenna (prior to amp installation) the SWR is a flat 1; use heavy gauge wires and connect straight to the battery; use ground straps; fine tune the amp to operate on 27MHz/11 meter (most of them were designed really for 10m operation).
    On the power mic, most brands works but get those with noise canceling such as Astatic. Additionally, try to get those with double grounding/shielding if you will pursue the amplifier.
    Cheers.
When I press the speak button, It display's TX and the other radio displays RX
tx is the word for transmit and rx is for receive
if you press the talk button, the unit goes into transmit mode and is received in the receiver of the other unit/s
now that your statement has been clarified what was the question?
Feb 26, 2016 | Radio Communications
I need a schematic
hard to do much without knowing what radio we are talking about here. Its more than likely a tx keying diode .
Apr 10, 2015 | Radio Communications
I have a Vintage kinematix reverb with 5 wires red,yellow,white,brown and black how I hook it up what are the wire? it also has a delay tuning knob
usualy you have a transmit recieve switch
like this
.....common
RX <<-- >TX ptt
so three wires
the ptt button common in a cb with 4 pins is also ground
should be
black screen and i think brown
but you need to meter out the ptt common and RX TX
for rx audio switched radios then one pin is RX one pin is TX one pin is common or ground for the PTT and also ground for the screening copper braids and also ground for the transmit audio
so you have 5 wires
3 will be PTT 1 will be audio and one audio ground
usually white or yellow
so i think black and yellow or black and white
black being ground
just look up the schematic or service manual for your CB
and check out the 4 pin plug config
there is only two usual ones
cybernet or uniden so.. easy stuff
look for like cybernet cb 4 pin wireup in google or similar
remember just meter out using the beep test range on a cheep multimeter too see which three are the PTT
so the common of the ptt needs connected to the copper screening and also to the black wire all to the ground pin on the 4 pin plug
you can short from the ground pin on the cb side to its TX pin and the set will enter tx mode
same with rx audio enable {if uses most cb post 1984 dont use RX audio hard switching}
so just three pins to worry about
Dec 03, 2014 | Radio Communications
Problem with Vertex VX-820
Try "reading" the radio before programming it. It sounds like the programming software is using the settings from one radio to write to another. It's highly probable that the firmware is different on the two radios.
It's always a good idea to "read" a radio befor trying to 'write' to it..
Dec 14, 2009 | Vertex Radio Communications
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Poor mic
whats the problem with your radio?
No Transmitted audio = mic cord faulty
Poor Rx / Tx power = poor SWR on the aerial
Dead radio = fuse or power supply faulty or protection diode faulty
Aug 20, 2008 | GE 35840GC3 2-Way Radio
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
Hearing loss
If your setup is able to rx and tx with no problems, sounds like his coax or antenna is bad. First, I'd try out his radio in your vehicle, since you know yours is working good. Just to see if it rx and tx good. If so, I would check his antenna and coax to see if they are good.
Dean
Rollin CBs
Sep 25, 2007 | Cherokee CBS2100 40-Channels Base CB Radio
Radio Communications Logo
184 people viewed this question
Top Midland Radio Communications Experts
Iron
Iron
AnyMHz.com
AnyMHz.com
Steve
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
