Question about Altec Lansing 5100 Computer Speakers
During the speaker configuration in control panel (windows 7 ultimate) the center and subwofer make no sound, but windows recognizes that noise is being made represented by the green bar rising. However, when I listen to music or play games, both the sub and center speaker work just fine. I think this problem is also related to ventrilo application. When I have my speakers configured to stereo (2 speakers) I can hear people over my speakers, however when I set it to 5.1 surround I cannot hear them. Please advise.
djnick989
  • 1067 Answers
SOURCE: no sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Posted on Jan 09, 2008
SOURCE: One speaker not working
I called Altec Lansing Technical Support:
Altec Lansing
535 Route 6 & 209
Milford, Pennsylvania 18337-0277
T. 866-570-5702
T. 570-296-4434
F. 570-296-6887
They stated that the case is not made to be opened (Great Design...NOT!) They suggested I remove the sub-woofer cable and clean the pins with alcohol. Of course, you should remove the AC plug first.
One other suggestion I would make as a last resort, for this and other problems. With the unit unplugged, pull off the Volume Control Knob, and the sfx knobs.  Spray electrical contact cleaner in the openings, and hope it reaches the dirty areas.
Make sure all the cleaner has evaporated before reconnecting the unit.
Good Luck
Posted on Feb 13, 2008
SOURCE: No sound coming from Altec ADA215 speakers
http://list.driverguide.com/list/company64/
Posted on Feb 11, 2009
darktowernz
  • 225 Answers
SOURCE: Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Posted on Dec 06, 2009
pappapumpdaf
  • 635 Answers
SOURCE: only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Posted on Mar 09, 2010
Audio device not installed
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 03, 2013 | Microsoft Windows 7 Ultimate 32bit
My soud is not working,ineed to instail sound drive it to be come
Jan 30, 2013 | Microsoft Windows 7 Ultimate for PC
Having problem with my soiud on motherboard p5sd2-vm on windows 7
The green 3.5mm audio input should be all you need. The speaker system should daisy chain. There is a speaker configurations in Windows. Go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or .1.
Oct 17, 2012 | ASUS Motherboard P5sd2-vm
I installed Windows 7 ultimate in my toshiba a300 laptop.I installed all drivers,there is no yellow mark in divice manager.but sound card name is not showing in that list.It is not detected.now what i have...
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
hope it helps
Jul 02, 2012 | Toshiba Satellite Computers & Internet
Creative sb 5.1 vx low volume on windows 7
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted
hope it helps
Jun 22, 2012 | Creative Sound Blaster 5.1 VX Sound Card -...
I reinstaled my computer its a Gateway with windows 7 to factory settings and now my subwofer is not getting any sound. The other speakers work fine, I checked all the volume controls, cords power. the...
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality then apply
hope this helps W7
Jul 27, 2011 | Boston Acoustics BA745 Computer Speakers
Intex headphones are not woring in my system. i installed windows7 ultimate. Any drivers want to be install to work my headphones. pelease give reply...
intex head phone not working in my system but speakers work properly.i install win 7 ultimate.how activate my head phone.this prblm occur only after my system formated?
Jul 22, 2011 | Computers & Internet
My 5.1 channel speakers are not working
WHTS YR SPEAKER MODEL LOOK FOR THE INPUTS U R PROVIDING THE SPEAKER SYSTEM IT MUST HAV TWO FRNT TWO REAR ONE FR SUBWPPFER AND ONE FR CENTER CHEK YR SOUND CARD SETTNGS FIRST U R ONLY USIN STEREO OUTPUTS EO
Jun 06, 2010 | Microsoft Windows 7 Ultimate for PC
My pair comuter speakers work, and there pluged in right, but don't pay anything out of them.
I assume you have told Windows about you new speakers ???
(Start, Settings, Control Panel, Sounds and Audio Devices = Volume tab, Speaker Settings box, Advanced button ...)
Oct 30, 2008 | Dell A215 Computer Speakers
Altec Lansing 5100 Computer Speakers Logo
43 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
