Question about Amana AGDS902SS Gas Kitchen Range
The plastic sleeves that receive the control buttons i.e bake, broil etc. have broken. The buttons fall out what can we do?
  • Amana Master
  • 3,247 Answers
You can find the parts you need and how these fit together behind the panel in this diagram.
But the challenge is whether you will get these or will have to make one yourself. Check with your local oven parts store. Need to make sure the sleeves are temperature resistant.
Good Luck.
Posted on Oct 10, 2010
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 | Ovens
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Whirlpool range
hi the part # is AP 3008287 at Appliance parts pros.com infinite switch controls the top burners thanks the appliance doc
Sep 29, 2008 | Whirlpool GY396 Electric Kitchen Range
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Amana AGDS902SS Gas Kitchen Range Logo
114 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
