Question about LG LSC26905TT Side by Side Refrigerator
I have a LG refrigerator LRSC 26925TT and I need to replace the Ice Tray - How do I do this?
    President:
  • 1,891 Answers
Most ref have ice makers. but if yours does not the the ice tray can be pruchased from l g / they are there own dist and most part supply houses do not have there parts . however sear's is a good source / try there web sight and i think you can order it there . i works for me ... mm
Posted on Oct 10, 2010
  • djaeger5 Oct 18, 2010
    Did not understand the problem.
How to fix LG icecube tray 3390JA115A
Hello there,
Fixing the ice cubes tray is quite simple, all you need to do is to hold the ice tray by the edge and gently slide it into the ice tray position. Pull out the drawer and place the ice tray into the freezer.
To make ice cubes, fill the ice tray to the water level and place it in the freezer.
Hope this helped. All the best Elect_Comp
Sep 22, 2011 | LG LRSC-26922 Side by Side Refrigerator
Ice bale will not drop down. It is stuck in the up position
heating element is bad and dose not heat to relase the ice .. replace ice maker is what usally has to be done....
Aug 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
Apr 30, 2009 | LG LRSC-26922 Side by Side Refrigerator
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice maker
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose.  Also check the fill tube where the water comes in and see if there is ice blocking the fill tube.  Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Jan 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
229 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
