Question about Fedders Room Air Conditioner A6J12E2A
I have a fedders ac wall unit model #A2D24E7DG and it's making a grumbling noise what could it be?
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
SOURCE: AC Problems
1 and 2 there two type of motor 1 has lubricating acces this youshould lubicate the other no noacces. but commonly if you lubricate and still noisy you change the bearings qty2 or sleeves qty2
2- common cause of ice
- thermostat on min setting
- thermostat defective
-air filter is very dirty
-evaporator is cloged no air pass throu
- loss of freon ( a/c is leaking)
Posted on Apr 30, 2009
SOURCE: Fan making noise in AC
pls try to lubricate it if it got oiling port as soon as possible. if no port you may change bearing before the damaging motor . also if this type of motor does not have bearings better to change it
Posted on May 01, 2009
  • 21 Answers
SOURCE: how do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Posted on Jun 17, 2009
SOURCE: My Fujitsu Halcyon Split ac/heater wall unit is
hi i have fujistu inverter2500/600 and it is shut down after 3 minutes after starting up
Posted on Dec 19, 2010
Have old fedders a/c and heater. Seems to rub on something when using and makes noise. Need to remove front or back cover to see what is making noise. Can't find anyway to remove either cover. ...
All depends how old. The 70's and 80's models slid out of the case. If this is what you have, take the front off and slide the unit out of the case. If it had screws to take out, they would be around the bottom of the unit.
May 28, 2011 | Fedders A6X05F2D Air Conditioner
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
Unit turns on,compressor kicks on but fan does not turn,motor makes humming noise
sounds like fan motor has gone bad or the capacitor to fan motor is bad...open up unit ,see if motor is frozen..does it turn freely..if so ,replace capacitor,or fan motor is bad...
Jun 09, 2010 | Fedders AED24E7F Wall/Window Air...
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
Fedders Room Air Conditioner A6J12E2A Logo
94 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
