Question about True T23 Refrigerator
Cant get the temp above 30 think i may need a thermostat
  • True Master
  • 3,361 Answers
Yes, a new thermostat is needed.
Posted on Oct 10, 2010
Check engine light on, Temp gauge is on low side. I get three lights flashing on ECU. I think its either 12, 21 or 30? Can't really tell if all long or short pulses.
Need to know what you are working on. Carb engine and codes make me think this is and OBD-1 system. Could just be a bad thermostat if gauge is reading true.
Jul 15, 2015 | Cars & Trucks
Refrigerator side keeps changing to lower temp
I think your thermostat is defect. Not registering the correct temperature. dial in a higher temp for the time being, but (let) replace the thermostat.
Jul 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Ranco k series thermostat
This thermostat is no longer available so be careful. Not knowing the workings though why not the direct approach. Adjust one screw in one direction (my guess is ccw) and see what temp changes. I would think the two screws are for high and low limits. If you cant get it higher (with knob at max) try the other direction first and then the other screw.... good luck.
May 16, 2014 | True Refrigerators
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
In cold weather my heating doesn't blow hot air
When your engine thermostat has failed or is sticking open, the engine fluid isn't able to reach a temperature that lets your heater core get hot enough to produce worthwhile heat to blow into the passenger's compartment. It is also not good for your engine to run below design temperature.
If you have a dashboard temp gauge, if your thermostat is stuck open, that gauge will probably stay in the cold area.
I would think that that is the problem, and I would have the thermostat changed (not a very difficult or expensive job).
Hope this helps you.
Jan 03, 2010 | 2001 Honda CR-V
What is the proper way to replace a thermostat on a 1997 Honda Passport?
Why do you need heat when its 80 degrees outside? What year ,engine, a clarification is needed. If the thermostat was bad it would kick the water out of the overflow bottle. More info needed!
Apr 26, 2009 | Honda Passport Cars & Trucks
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
True T23 Refrigerator Logo
85 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
