Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
I have a Pentair letro legend platinum pool cleaner, do i need a pool booster pump for it to work properly. My pool originally came with the 360 polaris pool cleaner it broke so I bought a used pentair letro legend platinum if does not work.
  • 640 Answers
You DO need a booster pump to power these automatic pool cleaners. It will not work without one.
Posted on May 11, 2011
Letro legend front wheel drive wheels no moving
take top off and adjust front wheels closer to gear but not too tight
Jan 17, 2013 | Pentair White/Gray Legend Platinum...
I need a manual on how to install and repair letro pool cleaner
pool distributor or amazon pool section remove bottom 4 screws see if hoses came off or belts if tires worn switch with backs front only drive if not moving adjust wheels to touch gears
Aug 17, 2012 | Pentair White/Gray Legend Platinum...
It flips on it's side, then goes around in circles and will not stand back up on the wheels. It's a Letro Lengend about 7 years old.
replace the float. It looks like a 3"x5" white or grey thing on the back just below the bag. Remove by unscrewing motion as you pull out.
Jul 20, 2011 | Pentair White/Gray Legend Platinum...
My great white pool clearner is not moving in the pool what might be the problem?
There are several thing that you can check. Be sure that both the filter pump and booster pump
are on and working properly. They might need to be cleaned. Also, check the wall fitting screen for debris and rinse clean. Test your pool cleaners wheel RPM and make sure that it is in the desirable level of 28-32. Make sure that your back-up valve is cycling. Check all the hose connections and
swivels for leaks that can cause loss of water pressure.
Nov 22, 2010 | Pentair White/Gray Legend Platinum...
Cleaner lacks power won't climb sides
Hey Walt, Check the hose swivels. Alot of the time the hose swivels leak water which defreases the flow to the cleaner. Also, depening on the model Letro cleaner you have, it could be the gear teeth in the wheels. epoolshop.com
Nov 03, 2009 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Do other brand name pumps work with a polaris 380 or do i need to use the polaris pump?
The Hayward booster pump would work but being in the same price range the Polaris is engineered for its cleaner
Jun 30, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
My Pentair Legend Pool Cleaner is too slow
Here is a link to the factory website where they have technical support for this kind of problem.
Legend Pool Cleaner
Feb 23, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
473 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
