Question about Pyle PLHB10 Car Subwoofer
Amp to go with this set up?
Don't know what amp would be right for this set up.
    Genius:
  • 1,550 Answers
Check the rms power of the speakers and then look for an amplifier who meets.
Posted on May 31, 2008
I don't know the verification code
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Press OK key for Menu.
  2. Press right navigation key twice to Select Settings & Tools.
  3. Press 5 or Phone Settings.
  4. Press 5 or Security.
  5. Enter lock code, then press OK. The default lock code is the last 4 digits of your phone number.
  6. Press 3 or Reset Default.
  7. Press OK, select Revert then press OK.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
Dec 20, 2012 | LG VX5300 Cellular Phone
Stalls when stopping at a junstion
right so we know it is a renault & we know it is a 2001 model & we know it stalls at junctions but......... we don't know what model of car or van or minibus or vehicle it is!!!, this is all relevant as all models are different & It could be many things.
Sep 13, 2012 | Renault Kangoo Cars & Trucks
I don't know which is right x-sus & y-sus or power supply 12/22 codes
If they are on left and right sides look from front of set--if not Google the model for a service manual which will have a pictorial showing which is which.
Jun 13, 2012 | Sony Televison & Video
What would be the best settings on a pyramid arctic 1000 watt amp for one JL audio w1 12
Your sub is a 4ohm woofer, running it in bridged mode + on right connection - on left connect as market on sub will give the best output. Your sub is rated at 75w to 300w and in this configuration will be getting just over 100w which about all the amp can provide with your sub/amp combo.
I don't know where they get the 1000w rating from either? the maximum the amp can possibly provide is 150w if running a 2ohm woofer in bridged mode.
Mar 08, 2012 | Car Audio & Video
I do not know what color to use the RCA jack in
RCA Jacks are usually white & red for left and right speakers and yellow for video. If you don't have a three piece set - then they are probably just for speakers and its one for right speaker and the other for left speaker.
On the back of the tv, the RCA jacks plug into the incoming area - with the red & white going to the speakers right and left and the yellow to the video jack. Then you need to choose the input method on the tv menu set up that matches in the one you chose on the tv. Examples of input methods are AUX, Antenna One, Antenna two, ect. With the tv turned on - keep changing the choice of input until you find the one that gives you a picture.
Jul 17, 2011 | Samsung Televison & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
How do you connect the PS3 to internet (wireless)????
First power on your PS3 , TV , & Router ( if you own the internet connection your going to connect to ) . Then select your User ID upon login . Scroll Left till you hit the Settings Menu , scroll all the way to the bottom & select Network Settings . Now select Internet Connection Settings , select Easy , Wireless , Scan . Now select your Wireless Network from the list that appears , confirm the SSID ( network name ) , & the type of Security Setting ( if you don't know connect a PC to the Wireless Connection & you can see the proper settings there ) , Enter a WPA Key or other type of Encryption if neccesarry , now confirm & test your Connection . It should run through a series of tests from connecting to the network , to a speed test . If all went right you should now be online & ready to game .
Apr 15, 2011 | Sony Playstation 3 (PS3) Console
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Pyle PLHB10 Car Subwoofer Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
