Question about E-Machines T2893 PC Desktop
My emachines t2893 desktop won't turn on it says it has power but the thing itself wont turn on i see a green light at the back of the desktop which means it has power but for some odd reason it wont turn on for me to use it everything seems to be okay in it but idk whats wrong with it
sandrew
  • 2961 Answers
SOURCE: T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
Posted on May 06, 2007
sids8065
  • 61 Answers
SOURCE: My emachines wont turn on
also in addition to the above, try reseating the ram chips..take them out individually and plug them back into their respective slots..might be the miracle cure..If the motherboard fan turns on, it might just be bad memory..replace RAM chips
Posted on Mar 03, 2008
SOURCE: emachine T2742 - Will not power on
Unplug every thing except /PS,CPU,and turn on
If CPU fans are running,and you do not hear any beeps
,it  is most likely a fried motherboard
Posted on Apr 20, 2008
crayzeetrayn
  • 837 Answers
SOURCE: T2893 e machines wont turn on
It sould be as simple as the on/off switch being bad .. the power supply could be bad .. it is powering the 'led' enough but it is faulty and cannot power the machine.
Try disconnecting all the components .. cd, hard drives, floppy ,etc .. but leave the power plugs on the motherboard .. try ...see if the CPU fan or power supply fan spin up..
Posted on Jan 04, 2009
cpenzes
  • 1102 Answers
screen blak
open the tower and follow the switch wires make sure they secure in the motherboard
be careful cause they are easy to break but if the tower was moved around it probably came loose
Posted on Jan 15, 2009
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
Emachines T2893 , will not power on, there is a small green light on inside on a board.
Suggestion is to bypass the Power On switch, to see if the problem is the Power On switch, or a bad Power Supply.
If upon bypassing the Power On switch, results in the Power Supply coming on, the problem is a bad Power On switch.
If bypassing the Power on switch results in the Power Supply does Not come on, the problem is a bad Power Supply.
I would like to refer you to a previous problem, that I just gave a solution to concerning this,
http://www.fixya.com/support/t4915632-compaq_presario_sr1620nx_desktop_turn
May 31, 2010 | E-Machines eMachines Desktop PC
Does the T2893 have to have an ATX power supply specifically for the emachine? I tried to upgrade to logisys 480w supply and the fans and a few lights come on, but the unit won't boot up.
there are TWO different power cables on the new machines. (not just two parts to the ATX)
one is the ATX like you are used to.
The other is a small four-prong plug (coming off of the power supply - look for yellow and black wires) find the matching receptacle on the motherboard.
good luck
Oct 20, 2009 | E-Machines T2893 PC Desktop
T2893 desktop did not power on when I hit the power button the green light is on the motherboard change power supply
E-Machines are notorious.....I had the same trouble with my T3624, replaced the MB and alls' well. The green light just shows the power is connected.
Oct 14, 2009 | E-Machines T2893 PC Desktop
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
I'm pulling my hair out...
Possibly .. but you could also have a bad power switch from the front panel ..
Jan 23, 2009 | E-Machines eMachines T3830 PC Desktop
Since you are looking inside, try this. Trace the wires that come from the power switch back to the Motherboard. The wires from the switch will connect to two pins on the motherboard. Carefully jump those two pins with a screwdriver and the machine should turn on. I would suggest doing this with all drives and cards unplugged first.
Jan 15, 2009 | E-Machines (T2824) PC Desktop
Jan 04, 2009 | E-Machines T2893 PC Desktop
May 05, 2007 | E-Machines T2893 PC Desktop
E-Machines T2893 PC Desktop Logo
105 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
