Question about Dell Computers & Internet
Can't detect the hard drive? - Dell Computers & Internet
    Sergeant:
  • 270 Answers
The drive has several aspects to pay attention to. IF it is an IDE, make sure the cable is properly inserted (pin one to pin one) (unless you have a connector that is keyed)
The power cord. And the disk select. This is 6 to 8 pins that designate the drive to be a Master drive, slave drive, or cable select.
The motherboards usually can on handle 4 ide devices, (unless additional hardware is installed)
IDE1 one master drive and one slave drive (Master on IDE1 is usually the MAIN boot drive)
IDE 2 one master and one slave drive
Hope this helps, without more information on your problem, this is what I think will help.
good luck and don't forget to vote!!!
Posted on Oct 10, 2010
Hard drive cannot detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 03, 2013 | Computers & Internet
It went in for service when we got it back it only turned on once. now when we turn it on the screen is black and on the top left corner the cursor is flashing and if you press on a key it makes a loud...
There are two possibilities, damaged memory and hard drive not detected or damaged. Most likely is, the hard drive is not detected or damaged. The characteristics of the hard drive is damaged, when you turn on your laptop, you are like the sound of this
To be sure, the hard drive is in trouble, press F2 to enter BIOS, check your hard drive, or check the hard drive is detected or not.
If the hard drive is not detected and didn't sound the hard drive is damaged (like in the video), the hard drive can be repaired and the data can be saved. Solution: take it to the Service Center.
If the hard drive is not detected and the sound of damaged hard drives, optical damage your hard drive. Solution: replace the hard drive.
Sep 23, 2011 | Computers & Internet
I cont intstal win xp in my toshiba U200-148 laptop
you can use another installer coz maybe your installer have some scratches
May 22, 2011 | Computers & Internet
Windows did'nt find any hard drive
Go to the BIOS configuration and see it the BIOS detects the hard drive. If it doesn,t detect the hard drive then the hard drive coulf be faulty.
Another way to check the hard drive. Remove the hard drive and connect it to an USB hard drive adapter and then connect this to a computer's USB port. If this computer does not detect it as and external storage device, then the hard drive is faulty.
To get your laptop operational again, insertl a new hard drive and install Windows on this hard drive, together with the laptop's device drivers and your programs.
Sep 21, 2010 | Computers & Internet
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
Bios not find hard disk
May 24, 2009 | Acer TravelMate 2303LCi Notebook
My bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Mar 03, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Computers & Internet Logo
97 people viewed this question
Alun Cox
