Question about Whirlpool Washing Machines
Washer keeps running - Whirlpool Washing Machines
  • prem mathew May 11, 2010
    Try to state your problem here in a more detailed manner..........
  • 114 Answers
If it keeps running and does not cut off automatically, you most likely have a defective timer.
Posted on Jun 05, 2008
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Constant running of water
You need a new water inlet valve. this will fix it.
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Washer keeps draining
Sounds like you may have a siphoning problem. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
Oct 29, 2008 | Frigidaire FWS833A Top Load Washer
Water doesn't stop
you have a defective hot water inlet solenoid valve. you have to replace that part.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Washing Machines
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Water keeps running
missmelissa, sounds like you are siphoning. Lift the drain hose from the drain and see if it fills then. You need to have a air gap on the drain so you don't get the siphoning affect. Catriver..post back.
Feb 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
