Question about NetGear DG834G Router
Flashing Orange Light
I am having problems connecting to the internet. This is an intermitent problem. Sometimes I'll switch on and my laptop wil work all day. Then next time it wont connect. When I am not connecting the fourth symbol in, the internet symbol is flashing orange. Please advise
    Scholar:
  • 187 Answers
Usually it means the connection is dropping. Contact your ISP and have them run a test on your line. In addition (and they'll ask you to do this anyway), replace the microfilter and the cable that goes from your router to the microfilter, to help rule out faulty hardware.
Posted on May 31, 2008
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
What does it mean when the orange light on the ps3 flashes?
f there is an orange light on your PS3 then there are a few basic steps you need to take that stand a good chance at being able to fix your console. Firstly, check that all the cables and leads are correctly attached to your PS3. Sometimes a cable or lead may have become slightly unseated if you moved your PS3 or somebody/something bumped into it. Remove every lead and cable and then re-attach them, one by one.Next, power down your PS3 and leave it switched off for at least 30 minutes. From time to time the Playstation 3 orange light error can be caused by overheating, so by turning it off and leaving it you will give your console a chance to cool down. However, it is important to note that this is only a temporary fix to your problem, and the orange light error on your PS3 will come back.Finally, ensure that your PS3's network connection is working properly. If you connect your console to the Internet via a wireless connection then this connection can sometimes be interrupted, thus causing problems with your console. Turn off your Internet modem/router and then reboot it. Also, try using a wired Internet connection to your PS3, if this is possible.By following the above steps you may be able to fix the PS3 orange light error.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
Orange flashing light on the internet symbol and the internet will not work
Hi your router is not configured the properly
jus follow the below steps wil fix your problem
open the internet explorer type in the url box 192.168.2.1 if doesn't works go to start->run ->type (http://192.168.2.1)
1. once you login to belkin router page
If your internet service provider is Cable then follow the below steps
* open the internet explorer type in the url box 192.168.2.1 if doesn't works go to start->run ->type (http://192.168.2.1)
* on the left bottow you will find restore factory defaults if asks password leave it blank
* select connection type on top left you wil find if asks password leave it blank now choose dynamic - click on next you will find host name box below that you will see change wan mac address click on it ->click clone -apply changes
* Now check internet status on top right corner if it says - Connected then you wil be able to go online
if still unable to go online then
* First disconnect router power cord,then modem power cord then back of modem you wil see a cable wire or co axial cable unscrew (if you have battery remove that too )it remove wait for three minutes and plug all back
If your conenction is DSL Connection
2. on the left bottow you will find restore factory defaults if asks password leave it blanknow check internet status - if says connected you wil be able to go online
3.if not choose connection type on top left you wil find if prompts password leave balnk next page you wil find host name below that just click apply changes
Sep 26, 2010 | Belkin F5D7234-4 Router
I am having problems getting conected to the internet on a daily basis.When it happens the orange light on the router is flashing. Checked all connections each time & all seem ok. Please advise.
well, kindly off the modem and on it again,, if still prob exist right click the internet icon in tool bar(two small pc) icon , right click and give repair,even then if prob exist switch off the pc&modem or restart it the prob ll be solved
Mar 26, 2010 | Proxim SkyLine Wireless Broadband Gateway...
Intermitant connectivity to internet (orange)
Ok well you might want to start with a router firmware update. Visit the router's website. i.e. linksys.com dlink.com etc. etc.
If that doesn't fix your problem we can try something else, but that's the best place to start for now.
You can also check out my new PS3 common problem and repair guide here:
Check out my common problem and easy repair guide here:
http://rescuetechla.blogspot.com/
It doesn't address your problem specifically but there are a few Tips of mine you should check out.
Please feel free to email me any other questions and don't forget to rate!
Thanks!
RescueTechLA
Feb 19, 2009 | Sony Playstation 3 (PS3) Console
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Aug 04, 2007 | Acer Aspire 3003LCi Notebook
NetGear DG834G Router Logo
306 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
