Question about Toshiba Computers & Internet
The wireless wont work the light doesnt come on its as though its disabled
    Problem Solver:
  • 13 Answers
SOUND LIKE THERE ISNT A WIFI CHIP INSTALLED...
1. TURN IT OFF
2. TURN IT OVER
3. LOOK FOR THE SMALL SQUARE DOOR(USE PROPER TOOLS ECT NO BUTTER KNIVES OR ANYTHING LIKE THAT)
4. UNSCREW SCREWS
5. THERE SHOULD BE A CHIP INSIDE WITH 2 SMALL WIRE ATTACHED, IF NOT THERE'S NO WIFI NEED TO PURCHASE A WIFI CHIP
Posted on Oct 10, 2010
My wireless wont turn on with the Fn and F2 key.It was recently formated so i dnt knw if thats the problem
If your computer was formatted then may be a posiibility it doesnt have the drivers for the wireless card. Or may be its disabled from BIOS.
Fisrt make sure drivers are installed else you need to install drivers from dell CD or get it from dell website http://support.dell.com
To check BIOS settings.... Turn off computer Turn on and hit F2 to enter BIOS setup Find if Wireless switch is disabled Enable it incase its disabled or set it to default. Save and exit restart computer....it should be working now.
Jun 22, 2011 | Dell Inspiron E1505 Notebook
I am only able to obtain wired internet access despite wireless configuration. My computer does not detect the wireless network. Is this because the SSID has been disabled? How can I unhide it?
yes if u have the ssid disabled it wont detect it u have to log into ur router and set it to broadcast the ssid
log into the router and click on advanced wireless settings and clear the check mark where it says disable ssid and save settings
also is ur wireless card enabled on ur computer
Feb 05, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
Wireless not picking up
Some laptops have a small round button on the front or a Function F3 key which acts a toggle, even though the drivers are installed, like this Evesham Latop.
Check to see if there is a light flashing some don't have this light (note its not the HDD spinning light)
This button is separate to the drivers they can be working fine, it like a tap and if you close it no signal can be sent to the router. And hence no connection to the internet.
You also need to make sure that the windows own service WZCSVC is stopped if you are using the NIC own software to input your WEP key for secure connection
Disable the service here using this tweak it can cause you problems.
http://rapidshare.com/files/260751524/Disable.WZCSVC.reg
LOL
Oct 07, 2009 | Computers & Internet
How do u turn on and use wifi on Inspiron B130?
There should be a wireless icon next to the time (lower right hand corner of your screen) that you can right-click on and Turn radio on. Hit the function(blue button lower left) and F2 if there is a tower on F2, it may be a differant F number on the top. If that doesnt work, right click my computer and click manage. Then Device monitor, and then click the + next to network adaptors and make sure the wireless symbol doesnt have a symbol on it besides the green chip. If its red its disabled, right click enable. If its yellow you need a driver for it, find it on Support.Dell.com and install the driver.
Jan 11, 2009 | Dell Inspiron B130 Notebook
Wireless light
Is the Wireless signal turned on within your 2Wire options?
Try turning it on.
Aug 23, 2008 | 2wire (1000-000057-000) Modem
The wireless keeps saying disabled.. it wont connect and it cant find the available networks.. there is no problem with the network cos it works fine on the ohter computers/laptops in the house and...
Hi sayeh,
I don't know if some of your IT friends had check the Wireless Zero COnfiguration,lets check it out.
start>run> type in services.msc
scroll down to Wireless Zero Configuration
check the status,
right click on it and click either start/restart
hope it helps
Jun 23, 2008 | Computers & Internet
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
IT DOESNT WORK OUT
Sounds like your wireless is disabled.
If your using windows xp, check the following.
Go to your start menu
go to your control panel (might be under settings, might not.)
from control panel, if it says "Choose a Category" click switch to classic view.
open your Network Connections Icon.
If "Wireless Network Connection" is grayed out, right click it and choose, "Enable."
In Windows Vista
Go to the bottom right hand corner of your screen to the icons.
Right click on the double monitors (network connection)
Select Network and Sharing Center
Click on Open Network Connections
If "Wireless Network Connections:" is grayed out, right click it and choose, "Enable."
If it is enabled, and you already have wireless built in to your laptop, then it's possible the wrong wireless card is enabled. If this is the case, when you open your network connections, you will have two Wireless Network Connection Icons.
A Wireless Network Connection, and a Wireless Network Connection 2. Make sure 2 is enabled, and the first one without a number is disabled.
Let me know if this helps.
Mar 17, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
