Question about 2wire (1000-000057-000) Modem
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
    Guru:
  • 382 Answers
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Posted on Oct 10, 2010
Testimonial: "Thanks!"
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Wireless Troubles with 2wire
you need to check the wireless encryption for your 2wire modem..
Sep 20, 2008 | 2wire 2700HG-B Router (2700HGB)
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Belkin Dongle
You have to make sure first that the working pc is getting its internet connection from the BELKIN and not from the modem. To check that, right click the computer icon at the butoom right of your screen, click detail. ip address that is ok is in this form 192.168.xx.xx. If you are getting like 74.xx.xx.xx, that means that you are getting connection from the modem. THE MODEM ONLY GIVES ONE CONNECTION, MEANING THE ROUTER IS NOT FUNCTIONING CORRECTLY. After doing this you can give a follow up question.
Jan 19, 2008 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
2wire (1000-000057-000) Modem Logo
399 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
