Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Need a different thermostat unit will get no warmer that ten
    Sergeant:
    Champion:
  • 351 Answers
Hi go to lower numbers to lower temp jim
Posted on Oct 11, 2010
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
How to setup honeywell th3210d1004
you need to change the differential pressure to 3 degrees.that means the unit will not kick on unit it is 3 degrees warmer then the setpoint
Mar 06, 2013 | Honeywell TH3210D1004 PRO 3000...
Its too frozen all the time
There is a thermostat in the refrigerator section. Yes, even the one that operates the freezer is in the refrigerator section. Try turning it to a warmer setting. Almost always, it will say on the knob which way to turn for colder or warmer (different manufactures do things differently). If this does not fix your problem, it means this thermostat needs to be replaced.
It would be best to have an appliance repair technician do this--unless you have some experience with electricity and general appliance repair.
Don
Mar 17, 2012 | Refrigerators
Have a small electra fridge freezer and would like to know which way to turn the thermostat dial eg to get colder / warmer.
One of the easiest ways is to wait for the unit to turn on then reach in and turn the stat until the unit shuts off that is the warmer direction.
Jun 23, 2011 | Refrigerators
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
Package unit outside. thermostat inside calls for heat, have to turn thermostat up about ten degrees over the temp inside to get unit to come on and heat. It will work a few days then wont come on at all....
Yes it could. Probably the Thermostat Transformer in the outside unit. Unless, it's millivolt control. In which case the Thermopile or Thermogenerator, which is part of the Pilot Assembly needs to be replaced. Neither part is expensive, but should be done by a qualified serviceman. That way you'll get the part that has the proper voltage.
Feb 16, 2011 | Goodman Heating & Cooling
Wha is a warmer
A warmer can mean two things when considering a refrigerator. The first will be a evaporator core warmer or heater. This device is essentially an element that keeps ice from forming on the core. It is controlled by a defrost timer and a thermostat. Once the timer reaches a set interval, it will initiate the warmer/heater to defrost the evaporator core. This mechanism will keep the core free of ice, which in return, keeps the unit operating as designed. The second type of "warmer" is a water line warmer or heater. This is a thin copper or steel line that is wrapped around the inlet lines inside your unit. This type of warmer/heater keeps the inlet lines from freezing over inside the unit. If the line freezes, they cant transfer water to the dispenser and ice maker. This style of warmer prevent s these important lines from freezing over.
Additionally; some side by side units have divider warmers to keep the condensation down that can form in the summer months. This type of warmer is mounted inside the frame, near the divider, and is an automatic functioning device.
Jul 23, 2010 | Refrigerators
Water will not heat, switch was turned on, thermostat dial was checked, unit was plugged in.
Check the hi-limit thermostat on the boiler, then the thermostat inline from the element to the ready light.
Nov 11, 2009 | Bunn 12 Cup, Digital Coffee Brewer with 3...
Takes long time to make ice then stops
What is the model number of your unit? Some of the icemaker is designed to harvest when the thermostat is cycles. So every 1/2 hr on some and longer on others. If you have a BI series then make sure the thermostat is set to a warmer temperature. That way the thermostat will be satisfied.(counterclockwise). Listen for the compressor to cycle off. When that happens then the icemaker should harvest. If not then the thermostat could be bad. If its a different model then Let me know and I can try to help you thru that.
Jul 30, 2009 | U-Line Icemaker
Frost forms in freezer, blocking vents so temp in both freezer and fridge is warmer than normal
You have an issue with the defrost system, either the timer, thermostat or heating element. Probably the defrost timer refer to the manual to find it. If you don't have the manual check the makers web site for a parts breakdown. You should be able to put it into defrost manually by turning the knob and see if that helps. You may need to do this sevral times as it only stays in defrost for a little over twnety minutes and run cycle for 6,8 or ten hours. If the ice build up is heavy then twenty minutes may not do the trick thus the need for repated defrost cycles. If it does the trick replace the timer. If not check the thermostat and heater element.
May 18, 2009 | Kenmore 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
47 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
billconfused
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
