Question about PC Chips M955G Motherboard
Thanks man Thank you so much for the manual. I think I have connected everything up but when I connect the power lead up and attempt to turn it on, there is nothing! no lights or sound! Would I need a bigger transformer? How would I know if I need a bigger one? Thanks again man!
    Scholar:
  • 187 Answers
Follow the PWR cable from the case to the mother board, and make sure it goes to PW_ON, and the PWR LED, goes to PWR_LED on the board (see page 33 of the manual). Additionally check that BOTH power cables from the PSU are plugged into the board (see page 18 and 28 of the manual, ref PW1 and PW2)
Posted on May 31, 2008
2005 pontiac montana won't start after boosting another vehicle
I have to ask, did you connect or attempt to connect the cables the wrong way round! Sounds like a main fuse has blown, some vehicles have a fusible link directly connected to the battery, you may have disturbed or broken a wire off the battery when you connected the boost leads. This seams like the only explanation. Good luck
Jan 03, 2014 | Pontiac Montana Cars & Trucks
Everything is connected correctly but nothing will print. When it attempts to print it makes a weird noise.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED ,to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
Sep 13, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I am having problems with booting my PC. When I turn it on, it does not boot the first time. I turn it off again and then it boots fine on the second attempt. Is this normal? Thanks for any advise. My...
no this is not normal
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 01, 2011 | Gigabyte GA-890XA-UD3 Motherboard
I canNOT get my H2O Man to play my downloaded iTunes--I've tried everything I can think of! Power light just fast-flashes blue then turns red.
Hi llaprise,
Please visit our website www.intova.net and go to the support page. There, you will find help manuals for our products. Here is the link to the page that can help you with your problem: http://www.intova.net/wp-content/uploads/2010/06/MAC-iTunes-music-conversion-to-MP3-for-H2O-Man.pdf
If you have further questions, please call us at (808) 837-0074 or e-mail us at kevin@intova.net.
Thank You,
Intova
Dec 27, 2010 | Sport & Outdoor - Others
What does three long beeps soyo sy-p4vgm indicate? Everything was running well. Powered down, powered up..beeps thanks
might be a faulty connection/lead make sure they have secure connections
test all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also cd/dvd/3.1/2 inch floppy drive leads
hope this helps
Sep 30, 2010 | Soyo SY-K7V Dragon Motherboard
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 | Tefal Irons
Concecrning the previous post, thank you so much that did indeed enlighten me a little although now i am thinking perhaps the power supply doesnt agree with the board. i did as you said and also unhooked...
That connector is the CPU power connector. Plugging it in and having the problem surface signifies either the CPU is blown, or there is a short in the power lead. The only way to make sure is to either try a different CPU, or connect your power supply to another motherboard.
Aug 09, 2009 | ECS KN1 SLI Lite (V1.0A) Motherboard
95 cutlas sup. you can drive it park take the key out go back latter the car wont start.my husband can come get me when he gets there some times it will start sometime not.he thinks it the chip in the key....
Check lights, etc, check battery grounding. If that turns up nothing, your husband just may be right! You also need to check power at small wire connection on starter with key turned to start position . There should be 12v at large connection and 12v with key turned at small one! If there is power at small lead, starter may be bad.
Mar 13, 2009 | 1995 Oldsmobile Cutlass Supreme
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
PC Chips M955G Motherboard Logo
65 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
