Question about Cobra 29 LTD CB Radio
Used to receive and put out up to 7 or 8 miles now only half mile range and squelch made all kinds of noise now doesnt make any what has happened
    Guru:
  • 773 Answers
This could be atmospheric, meaning it may have nothing to do with your radio.
There are a few things that could be happening. there is a phenomenon called skip that occurs occasionally. It is when solar flairs charge the ionosphere with energy. When this happens it causes radio signals to bounce off it and travel hundreds and thousands of miles further then they normally should. When this occurs, you will have a lot of back ground noise.
Next, some days there is very little atmospheric interference. Some days you can turn on the radio and there is almost no noise.
This could be it. If not then it could be any of the following.
  • RF gain is down. turn this all the way up.
  • Antenna problem
  • Coax problem.
After checking all these, if the problem still occurs, then there may be an issue that you will need a tech for.
Posted on Oct 11, 2010
Can these discovery Expedition two way radios work when you are just three minutes away
They have a maximum range of 3 miles (and this will vary depending on surrounding terrain. They will communicate with each other even if they are side by side, so there is no MINIMUM range to worry about. In a city, I would suggest the maximum range would be more like 1 mile consistently, and 3 miles, possible more, on prairie.
Oct 01, 2016 | Discovery Expedition DX2500-BP Dx2500 Frs...
On this model #75-509 what is maximum distance for comunicating
I think that is a 1 watt radio. In optimal conditons you should be able to get a 3/4 mile solid, maybe a bit more. In a not so great situation, such as woods or buildings in the way about 1/2 mile or a little less.
Feb 07, 2016 | Radio Communications
Have interference after incoming transmission which remains til mic is keyed stays clear til after next incoming.
perhaps the squelch is set too "open". Try to program a tone code into the radios. Many times the manufacturer expects you to use a tone and they set the squelch too high, or open. This causes the squelch sound because the radio is trying to pull in weaker signals. If you are using a tone code, the model of the radio is needed to tell you if the squelch can be adjusted.
Nov 02, 2015 | Uniden Lot Of 3 Gmrs 10-mile Range Uhf...
I get white noise on my walkie talkie...only when I use the walkie talkie does it stop...what do I need to do to stop this and have it function properly
Sounds like the 'squelch' is not high enough. Check the manual how to raise the squelch level. Then the receiver will be silenced until you receive a strong enough signal.
Jun 23, 2014 | Uniden GMR3040-2CKHS 30-MILE R
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
Homepatrol scans but does not stop at any signels
Squelch setting set too high perhaps, reduce the squelch until you can hear something, then turn it up slowly until it start to scan again.
Radio Control Bar
The row of buttons across the top of the Main screen lets you fine-tune HomePatrol-1 reception, access Help, and reenter system configuration.
Button
Definition
Squelch
Sets how strong a signal must be before HomePatrol-1 stops on it.
Range
Controls how many channels are selected based on your location and systems' locations. Small range settings result in fewer systems and departments selected. A selection bar lets you set the range in 2-mile increments. Each screen tap is 0.5 miles.
Atten (Attenuation)
Reduces signal interference if you are in an area where there are a lot of radio signals. If Attenuation is set to ON, the status indicator turns red.
GPS
Displays the status of a connected GPS unit.
Help
Displays Help text.
Tap and hold to redo initial setup configuration.
Hope this helps
Ed
Oct 03, 2013 | Uniden Radio Communications
When i transmit if the other vehicle is anything over a mile away they get a lot of static. I can receive them clearly at up to 5 miles. What do I do to get better transmission? I have a K40 antenna...
Well if they are not hearing you over a mile but you hear them over 5 miles that is a good indicator that your antenna is working properly but your radio is not getting out there. First go ahead and check the TX knob. Turn it all the way to the right so you modulate as much as the radio will allow. Next turn the squelch knob all the way to the left until you hear static and then turn it to the right slowly until the static noise goes away. Some don't mind the continual static but I like to squelch it out. The TX being turned to the right will allow your radio to work at full capacity. If you still don't get reports much over a mile then you can try a power mike to help you out a bit. Your microphone could have seen it's better days and can for sure mess up your transmit. Make sure your SWR is low 1:1.5 is the goal not to exceed 2. If all that checks out then have it peeked /tuned and aligned by a tech. Good luck to you.
Feb 06, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
T 5000 (Talkabout Hand held Radios)
Hi Mark,
I understand your concern with the actual range of the Motorola T5000. Being UHF radios, they are severely limited by any obstruction in between, be it trees, buildings, hills, foliage, terrain and any others that would block "line of sight". Additionally due to the inherent design restrictions imposed on these radios, the FRS channels are limited to pushing out 0.5 watts making the GMRS channels better choice since the radio will be transmitting at 1 watt. To my knowledge, channels 8 - 14 are FRS only.
Possible things you can try to improve transmit distance are:
1. use AA Alkaline batteries instead of the rechargeable ones;
2. disable or minimize settings of interference eliminators, Quiet Talk, noise filters, coded squelch or CTCSS;
3. replace the stub antenna with a Larsen Quarter wave. You may need to install a BNC mount to accommodate the Larsen. Incidentally, this will also improve the receive range and not only the transmit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Cobra 29 LTD CB Radio Logo
29 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
